LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
ael911's Avatar
Originally Posted by Henry Schmidt View Post
If you are looking to build something really trick, grind the rod journals on the 2.2 (66 mm) crank the except 3.0 rods. When you grind the crank properly, you can get a larger radius fillet that will greatly increase the crank rigidity. Knife edge it and it gets almost as light as a non counter weighted crank.
At this point you can install the GT3R Pankl titanium rods [130 mm center to center length] and use a standard piston as you will have restored a the standard dimension to the crank and rod combination. In a 2.5 you use a 90 mm RS piston to get 7.6:1 @ .060 deck.
With a 95mm 8.5 CIS piston (78-79 SC) you get the same CR .7.6:1 @ .060 deck.
The alternative to Viagra...Henry's motors
Someone please sell me a case so I can get my own 2.8SS porn....
'75 911S Silver Anniversary #164(Formerly JTO's)
Rebuilt 2.7 with full ARP, 9:1 CR.
SSI, GHL, ER polybronze bushings, finned oil lines.
Lowered and corner balanced. CIS retired, now PMOs!
'65 912 slate gray sunroof (driving project)
Old 01-19-2008, 09:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
mcinturff's Avatar
We'd love more tricks like these.
Now here's food for thought: When chevy heads build a 325, 352, or 377, they take a 400 block (large journal) and use extra thick bearings, or bearing spacers (big no,no) with a 302, 327, or 350 crank; would this be possible in a Porsche as the SC case can be thought of as a 400 block and the 2.2s crank can be thought as a 302 crank.
1988 930 Cab - Peru Red
1983 911SC - Black
1992 964 C2 Cab - Amazon Metallic Green
Old 07-20-2008, 09:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
Walt Fricke's Avatar
Mac
Yes and no. All the main journals except #1 are the same on the 66mm and 70.4mm cranks. The 1978 and on 930 (includes SC) cases have the same journals. Only difference is #1, which has a wider crank journal (facilitated the switch to the 9 bolt SC and later flywheel) and hence a wider hole in the later case for the wider crank journal and bearing. But I've talked with a guy who just made some kind of spacer so a regular SC case would be run with a 6 bolt 66mm crank. He must be a pretty good machinist. I see no advantage to this other than the fact that it lets you use the relatively common SC/3.2 case rather than the rare 930 cases from '75-77.
Walt Fricke
Old 07-20-2008, 10:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
3 restos WIP = psycho
kenikh's Avatar
Walt Fricke
Pretty big advantage.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-21-2008, 10:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
mcinturff's Avatar
Do you perhaps know the guy's name or business name? This would be a great product to market.
1983 911SC - Black
Old 07-21-2008, 08:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
Mac
I can't quite remember. It might have been Pat Williams (patwilliamsracing.com is always worth a look). It might have been the guy from Zuffenhaus at the Charlotte Parade. It might have been Bruce Anderson. And it might have been someone else.
I doubt there is much of a market: how much would it cost to make 100 of them, and how many would pay how much to purchase one? By and large guys like larger motors, not smaller ones. Why build a trick 2.8 when you can buy a 3.6? Simpler to make them each time a customer says can you make one of these.
The 2.8SS is a neat motor. But had I been able to predict the formula we came up with for PCA GT classification, I'd have just built a high squeeze, tricked out 3.0. Fewer special parts, and I'd not be looking at how to shed even more weight from my car, which is already pretty stripped down.
But I'm slowly forging on with my SS. To be decided: what valves to use in the 3.2 heads I have for it. After that, what cams.
Walt
Old 07-21-2008, 09:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
Try not, Do or Do not
Henry Schmidt's Avatar
New 9 bolt, 66mm cranks are coming and they will resolve all of the needs for short stroke engines. Chrome molly, modern oiling, full counter weights and more.
Countdown about 3 weeks or so.
Why just 66x95 when 66x102 is possible? 9200 rpm 3.24 ltr.? Yikes!!!!
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-22-2008, 06:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
mcinturff's Avatar
Now you're speaking my language. Who is making them?
1983 911SC - Black
Old 07-23-2008, 10:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
Disclosing some of the information about our new product before it exist seems somewhat premature. Once I have the first run in my hands and have completed the inspection and testing process, I will share all the pertinent information with everyone who's interested.
I will say that the cranks are being made with 100% certified US materials (chrome-moly) and were designed and manufactured in So. Cal.
I've had my fill of dishonest Chinese manufacturers.
Henry Schmidt
Ph: 760-728-3062
Old 07-24-2008, 06:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
abit off center
cgarr's Avatar
Same company who have been making the 912 cranks by any chance? If so it will be a work of art!
______________________
Craig
G2Performance
Old 07-24-2008, 06:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
Gon fix it with me hammer
svandamme's Avatar
pricing?
Stijn Vandamme
BIMDIESELBMW116D2019
Old 07-24-2008, 06:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
No 912 cranks, at this time they are only making a few special order 911 cranks.
here's the only hint you get. Their main work is with very high engines.
pricing?
$3500-$4000 depending on developement work required. They will come with special main bearings required for this crank design.
Henry Schmidt
Ph: 760-728-3062
Old 07-24-2008, 07:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
svandamme's Avatar
great, i'll call you as soon as i win the lottery
Stijn Vandamme
Old 07-24-2008, 07:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
Product warning: If erection lasts for more than 4 hours, step away from the computer screen!!!!
Then call Extreem Escorts @ 1(976)-too-cute
Henry Schmidt
Ph: 760-728-3062
Old 07-24-2008, 08:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
abit off center
cgarr's Avatar
You need to re-title this thread to something other than "Short Stroke" then!
Craig
G2Performance
Old 07-24-2008, 11:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
mcinturff's Avatar
Henry, is that sound file on the Supertec site of a 2.8?
1983 911SC - Black
Old 11-23-2008, 05:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
YES
This is the engine. 2.8 SS stroke 66x95, twin plug, slide valve, 9.5:1 comp street gas.
Henry Schmidt
Ph: 760-728-3062
Old 11-23-2008, 11:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
svandamme's Avatar
Henry,
quick bump, i started hording parts, got the case, the crank, now the rest.
I'll be ordering Headstuds from you in the near future, sorry i can't order the 2.8SS direct, i'm poor, plus i like to get my hands dirty and diy a bit.
But do you happen to have a Dyno sheet from a stock 2.8SS , as you build em? Just so i can get an idea what the Benchmark looks like?
Stijn Vandamme
Old 10-13-2009, 08:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
Henry,
We have head studs in stock ready to ship.
As for the dyno sheets, we haven't torque tested an engine in quite a few years. We found when we had a dyno that everyone wanted a sheet but no one wanted to pay for it.
We get figures from customers upon occasion but those numbers are always subject to outside influences.
300 hp would be considered a reasonable top line and with milder street cams I would think 280 would be reasonable.
Good luck with your build.
Henry Schmidt
Ph: 760-728-3062
Old 10-13-2009, 08:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
svandamme's Avatar
Henry, 280HP with milder street cams?
define milder? DC60? DC40?
Stijn Vandamme
Old 10-13-2009, 08:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
