-   -   Short Stroke 2.8 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/239210-short-stroke-2-8-a.html)
Henry Schmidt 09-03-2005 10:48 AM
Short Stroke 2.8
Almost done, what could be nicer?
http://forums.pelicanparts.com/uploa...1125769608.jpg http://forums.pelicanparts.com/uploa...1125769643.jpg http://forums.pelicanparts.com/uploa...1125769658.jpg http://forums.pelicanpa[B]rts.com/up...1125769679.jpg
jpnovak 09-03-2005 12:20 PM
Is this 66x95? Early turbo C3.0 case? I think we all want more details.
kenikh 09-03-2005 02:22 PM
A 2.8SS is indeed a 3.0 carrera/turbo case w/ 95mm pistons and 2.0/2.2 crank by defintion (unless for some crazy reason he has a 962 crank in there; then you can use an SC case). SWEET motor. I bet is runs ~11:1 CR w/ those twin plugs and RSR cams for over 300HP at >8000RPM when installed. I must stop typing before the drool fries my laptop...
blue72s 09-03-2005 03:43 PM
Cool!
cstreit 09-04-2005 08:47 PM
zzzzzzzzzzingggggg!
gumba 09-05-2005 08:10 AM
I recently picked up a '76 turbo case and talked with Henry about building a similar motor using 46mm Webers. The compression ratio would be around 10.? /1 and would run on pump gas. I wanted to use it in a street car and as a backup race motor. After looking at that picture the best use might be in the living room as art.
3.4 twin plug in the works
2.8 twin plug in boxes
906 cams for sale
Henry Schmidt 09-05-2005 09:41 AM
HEY GUYS, THANKS FOR THE KIND WORDS.
What you are seeing is what happens when you love what you do. It's a blessing to be able to make a living doing what you truly enjoy.
Just a note: Dean Polopolus of 4 cylinder 911 fame is standing in while my arm heals and it's like having Babe Ruth coming in off the bench.
Even though his own engine building company keeps him busy, he found time to help a friend.
Come by a meet a legend.
vichang4 09-06-2005 08:19 AM
Henry,
What type of header system are you going to use on this engine?
Henry Schmidt 09-09-2005 07:55 AM
It's hard to teach an old dog new tricks.
1 and 5/8 inch flat collector header system with cookie cutter megaphones from European Racing Headers. Old school but very affective. We tend to lean towards old school solutions when building our engines because we like the overall feel and performance of the things we know work.
blue72s 09-10-2005 03:37 AM
I'm only guessing but I don't think it's that straight forward because I think the head combustion chambers are different, SC is 90cc and Carrera 3.0 is I guess 76cc? so it'd be difficult to get decent compression out of it. And I don't think they are interchangeable due to different head stud spacing?? And Just my .02
Correct me if I'm wrong!! ;)
Henry Schmidt 09-10-2005 07:08 AM
The heads on a 3.0 Carrera and a 911 SC are identical.
Henry Schmidt 09-21-2005 11:21 AM
IT'S DONE
AFTER OVER A YEAR IT'S DONE
2.8 SHORT STROKE 66 MM STROKE 95 MM BORE
2.2 "S" CRANK
3.0 TURBO CASE
TURBO OIL PUMP
SC HEADS PORTED TO 40 MM IN 38 MM EX
TITANIUM VALVE SPRING RETAINERS
TWIN ANDIAL DISTRIBUTOR
DC80 CAMS (JOHN DOHERTY) camgrinder on this forum
10.5 TO 1 COMPRESSION
MODIFIED 2.2 '"S" MFI PUMP, SEALED W/ BREATHER
41.5 MM BUTTERFLY HOUSINGS
41.5 X 46 MM MAG STACKS
SUPERTEC FUEL INJECTOR LINES
SUPERTEC ENRICHMENT DEVICE
EURO RACING HEADERS (George does a nice job)
226 FAN W/1.3 TO ONE DRIVE RATIO
SINGLE WIRE ALTERNATOR
RSR SHROUD ( GETTY DESIGN)
SOLID TENSIONERS (never fail)
THIS BAD BOY SHOULD MAKE 300+ HORSE POWER AND TURN 8500 RPM
http://forums.pelicanparts.com/uploa...1127326702.jpg http://forums.pelicanparts.com/uploa...1127326716.jpg http://forums.pelicanparts.com/uploa...1127326734.jpg http://forums.pelicanparts.com/uploa...1127326745.jpg http://forums.pelicanparts.com/uploa...1127326759.jpg http://forums.pelicanparts.com/uploa...1127326778.jpg http://forums.pelicanparts.com/uploa...1127326795.jpg http://forums.pelicanparts.com/uploa...1127326815.jpg http://forums.pelicanparts.com/uploa...1127326832.jpg http://forums.pelicanparts.com/uploa...1127326846.jpg
kenikh 09-21-2005 11:39 AM
Holy Schmoly. That looks the part!
davidppp 09-21-2005 11:57 AM
Truly a work of art..I bet the inside looks even better!
I'm interested about the MFI pump..I can see the enrichment mod..neat..what else is done to it?
And, I'm about to set up to machine a batch of heads for twin-plug for me and some buddies..
Not having access to any Factory twin-plug heads to compare, I'm planning to copy the 3.6L heads positioning for the second plug..I have some here to copy..
I'd be truly grateful for any hints please..
Kind regards
camgrinder 09-21-2005 01:59 PM
Very nice looking Henry.
Please say hello to Dean for me too.
Hey! this is my 500th post! woohooo
eddie914 09-21-2005 02:32 PM
What flywheel are you using?
Eddie
Henry Schmidt 09-21-2005 02:45 PM
Eddie
Factory RSR
blue82coupe 09-21-2005 03:05 PM
Beautiful work Henry!!! Dan
Wayne 962 09-21-2005 05:38 PM
Which distributor is that?
-Wayne
Henry Schmidt 09-21-2005 06:18 PM
-Wayne
Dick Evelrude (sp) sold by Andial mid 80s.
