993 engine case torque values?? Help!
I have a minor leak in my 993 that appears to be coming from the rear two bolts that hold the engine case halves together. I was able to tighten them a bit with a regular box wrench. This makes me a bit nervous and I would rather re-torque them to the proper value. Problem is I don't have a repair manual yet. Does anyone happen to know the torque values???????
Thanks!!! http://www.pelicanparts.com/support/smileys/yltype.gif |
I highly doubt that tightening those bolts will fix any leak. Just leave them alone. I would look for a leak above the bolts some place.
-Chris |
| All times are GMT -8. The time now is 04:45 PM. |
