| Registered Join Date: May 2005 Location: England
				Cracked Crankshaft
			Hi im having a full rebuild on my 85 3.2 Carrera and have had 2 cranks machined only to be told they are cracked? Is this common and if so can they be repaired? My original crank had a spun a bearing on one of the journals.
|  09-06-2005, 08:24 AM |
| Registered Join Date: Mar 2005
			Hello there. Its not uncommon for cranks to crack.. However, no reputable Porsche guy would do any work on a cracked crank...its very easy to test them.. The Industry Standard Test is to drop it from 3 feet carefully and horizontally onto a concrete floor. Most ring loud and clear, some make a muffled dong, and some fall in half.. Then you can proceed to spend cash on dye and or magnafluxing.. Kind regards David | ||
|  09-08-2005, 11:21 AM |
| Registered Join Date: Mar 2004 Location: City of Seattle, WA
			3.2 cranks seem to be particularly susceptible to cracking, compared to other 911 engines.  may be down to rod bolt issues, not sure.
				__________________ Andy | ||
|  09-08-2005, 12:20 PM |
