Send a message via MSN to MKEDF
Lightbulb Broken Pistons....Help!!
We brought out the pistons, and found out two of them had broken rings, and Broken Pistons!!..
But only two of them...funny thing is that rings are tearing appart just to move them, as well as pistons are, right on the ring holding area...
Is this isolated failure, or something else is causing such a mess...
Give me a hand, and feel free to speak your mind...
Mick
amazed rookie with rebuilds...
Old 09-26-2007, 07:58 PM
3.4 Bigger is better
88-diamondblue's Avatar
Detonation is what causes this. Hopefully other with more knowledge on this will chime in.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 09-26-2007, 09:52 PM
Less brakes, more gas!
euro911sc's Avatar
Exactly what happened to me:
And the pieces came a tumblen' down...
Cylinders were ok though.
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 09-27-2007, 07:42 AM
Super Moderator
cstreit's Avatar
You don't mention what type of car this is, but I would assume a Turbo, as these guys mentioned it's almost certainly detonation (knocking or bad pinging).
I'd also seen this once on an NA engine where the piston cooling squirters were blocked and the piston overheated, there was a lot more skirt damage evident than on your piston, where they look "fine..."
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 09-27-2007, 08:12 AM
Those do not look like Turbo pistons to me but I see damage from detonation.
Overly advanced timing, poor gas, lean fuel mixtures are all contributors to this phenomenon.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-27-2007, 08:58 AM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
Hey, I got the same exact piston sittin on my desk!!!!Welcome to the Mahle ashtray club.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 09-27-2007, 08:11 PM
mee too
Old 09-28-2007, 12:57 PM
Super Moderator
cstreit's Avatar
Troof. CIS pistons now that I look. These still have quite a bit of room for error, but *****ty gas and "someone" getting a little happy with the timing could do it fer sure!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 09-28-2007, 03:45 PM
SCOTITUDE's Avatar
went to JE's. if anyone needs replacements I got 5 good pistons waiting for a new home.
2008 E93 M3 DD
Old 09-28-2007, 04:01 PM
Just Went to the machine shop, they measured the pistons and said they are 2mm oval, out of shape..
Cyls are okay just polised them by the same machine shop willing to buy a set of P&C not shure about the pistons, but two of them are broken..
By the way they belong to a 3.0 SC 1978
Any one has a set of Pistons i can use? or willing to trade or something?
Best..
PS the Machinist said i could have been about overheating.....Thoughts??
Old 09-28-2007, 06:29 PM
does this sort of damage happen quickly with one bad tank of gas, or is it incremental over a long time?
Old 09-29-2007, 02:43 AM
Broken Piston, overheating..
As i have inquired, this problem was caused by the oil on the car it was too hot and lost itīs lubricant properties (The guage was not on overheat mark but close...)
The Pistons overheated and lost shape, which conducted to the disintegration of the rings, and deformation of the pistons...
Fortunately no scratches happened to the Cylinders and they are under condition of service..
So im buying a set of used P&C`s matched together so no mistake is done while assemble..
This set of Cyls are for sale, they have been measured and polished and still under service conditions...
Any one interested on trade or Buy??
PM me...
Old 10-01-2007, 04:54 PM
