-   -   Oil Tubes - Solid or Expandable? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/239901-oil-tubes-solid-expandable.html)
goldgunner 09-07-2005 06:39 PM
On a total rebuild, what's the consensus on which type oil tubes would be best to use - the Solids or the Expandables?
The expandables come in a Pelican kit - all the needed tubes and rings...the solids are purchased seperately. That would seem to imply the rebuild should have the kit, but from the pictures I see of the rebuilds, most use the solids.
So, what's the preference and why? please.
thanks!
jim
wilke3169 09-07-2005 06:44 PM
I used solids. One or make that 4 less joints to fail.
DonE 09-07-2005 08:35 PM
Solid - why not? Even tho the expandables don't leak, why not go for the cleaner look?
walt 09-08-2005 01:53 AM
Go solid. If they ever leak in the future they are easy enough to replace with expandables.
Rot 911 09-08-2005 05:01 AM
Used solids on my rebuild.
ChrisBennet 09-08-2005 05:39 AM
Solid = lighter, cheaper, less chance of leaks. It's a no brainer.
Walt Fricke 09-08-2005 09:28 AM
If I have them, I use solids for three (for the reasons given by others), and a collapsible for the one nearest the oil pump scavenge outlet fitting (nearest #3 cylinder). That way I can always get a wrench conveniently on the fitting and its attachment if something needs tightening or to be removed (like the oil line) between teardowns.
Walt Fricke
89red911 09-09-2005 04:43 AM
I used soilds when I rebuilt my motor.
The book I have says there is no real advantage to either. It seems it is a matter of preferance.
I agree that the solids have less places to leak than the others.
Just a thought but your rebuild did come with new collapsible ones so if you dont want to buy soilds dont.
aigel 09-14-2005 10:16 PM
The only disadvantage of the solids is the fact that you better not forget to install them before you slap the cam housings on. I was glad that my buddy had collapsible tubes when we did his top end. ;)
My pal had bought some nice turned collapsible Al tubes. I think they are made by Weltmeister. The best looking part I have seen come from that company to date. They may be worth looking into ...
George
