-   -   Rod Bolt Choices... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/240126-rod-bolt-choices.html)
arrivederci 09-09-2005 07:49 AM
Rod Bolt Choices...
I'm gradually gathering parts for a 2.8S build and have to decide on a set of rod bolts. What's the concensus here? Are the Raceware or ARP worth it? What are the advantages over factory bolts? I searched the archives and came up with -nothing-.
If it helps, I'll be running 10.5:1+ (maybe 11+) compression, but intend to keep the RPMs down to S specs.
Walt Fricke 09-09-2005 11:30 AM
Josh
If you plan this 2.8 to be anytning other than a mild street motor with a conservative redline, like 7,200 or so on a pre-3.2 crank, and lower on the 3.2, you are flat out nuts if you don't use Raceware or ARP rod bolts. They are significantly stronger than stock - 220,000 psi steels. Additionally, they can usually be reused several times before they are stretched too far. That is a good thing for a race motor, because those tend to need to come apart more often than motors used in less stressed applications. Less of a consideration in a street motor you hope to run for 100,000 or more miles before.
I sure wish bolts of this sort were available when I built my 2.3 motor, because a stock rod bolt failure (not clear if the fried bearing was cause or effect here) destroyed it. Equally bad problems with the 2.7 (I think that was the piston that pulled in half) that had Racewares left me with a bent end cap, and of course two bent rod bolts, but the bolts prevented the big end from getting loose.
I doubt you will find any of the guys who make a living doing this using stock rod bolts in engines built to anything other than stock specs.
I don't know what bolts Porsche used on their 2.8 race motors, but those motors got torn down between races typically and stock bolts I suspect are up to that number of fatigue cycles.
Walt Fricke
arrivederci 09-09-2005 12:13 PM
Thanks Walt -- that's exactly what I needed to hear.
YTNUKLR 09-09-2005 12:54 PM
ARP are really not much more in the scheme of things, maybe $100 or roughly double stock rod bolts.
Bill Verburg 09-09-2005 01:59 PM
I used Raceware on my 3.8
MotoSook 09-09-2005 08:38 PM
$185-205 (depending on who's supplying them) for ARP rod bolts inside a case that you don't want to have to open up again.... not a hard decision.
YTNUKLR 09-10-2005 11:02 AM
Nope! I use ARP bolts almost exclusively. Pretty much only on stock/mostly stock T/E/2.7/3.0 builds do I use stock.
jluetjen 09-10-2005 01:05 PM
What's the stroke of your engine? Here's a link to a thread that discussed the merits of some rod choices for 66 mm stroke engines, and that thread links off to a discussion of the merits of the different bolt choices.
arrivederci 09-10-2005 02:14 PM
I'm using a 70.4mm crank with 92mm JEs.
