Opinions on when to change oil pump sought
I posted this on the technical board, but realized that it probably belongs here.
Does anyone have specifications for the various oil pumps? What criteria do people use to decide when to replace the pump in a rebuild?
Old 11-11-2005, 08:25 AM
I look at the surfaces of the moving parts for damage/wear. If the oil pump looks ok then I reuse it. If you have the right oil pressure then you have a good pump. Of course you won't know this until after the rebuild but you can get a hint based on the oil pressure of the engine before you took it apart and the condition of the bearings.
-Andy
Old 11-11-2005, 09:53 AM
3 restos WIP = psycho
kenikh's Avatar
What year motor? If it is an early motor, you should replace it with a later one anyway.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-11-2005, 11:09 AM
