-   -   Splash valve (piston squirter) installation (http://forums.pelicanparts.com/911-engine-rebuilding-forum/241505-splash-valve-piston-squirter-installation.html)
Tom F2 09-17-2005 07:55 PM
Has anyone done this? I have one valve that's stuck open (i.e., air goes both ways through it, and the valve squirts a stream, instead of the atomized mist that I have seen "healthy" valves squirt). The engine is a 3.0 Turbo, apart.
Can anyone alert me to the perils/pleasures of this task?
Alternatively, anyone know a trick for getting the valve to work again? I have tried every solvent in the garage, except gasket remover, because I'm afraid the that the gasket remover might also remove the adhesive that holds the valve in place.
Thanks in advance.
Tom F2 11-11-2005 08:10 AM
Here's what I learned. The drill and 5 mm tap method works, but you have to carefully relieve the factory peening before you pull out the old splash valve, and you have to heat the adhesive. The bore comes out perfectly clean. It's better to make a little puller with a sleeve to sit around the squirter and a machine screw to actually pull out the squirter. This way, there's no risk of breaking off a tap in a bad spot. It's also good to make a drift from soft aluminum to tap the new splash valve in place. They don't go down far enough into the hole without a little persuasion, and the aluminum of the splash valve is too soft to hit with anything except soft aluminum or, maybe, plastic. The machine shop that I use made a nice tool for this that just goes into the bore, and which has a tip that fits into the top of the splash valve. Loctite 640 works great for this.
Also, the reason I had a plugged splash valve is that case sealer got into it. It seems that the last guy to assemble this motor put sealant on the faces of the bearing supports as well as on the perimeter of the case. Oh well, at least the case didn't leak.
ChrisBennet 11-11-2005 08:16 AM
Thanks for the unpdate Tom. Some people regularly do put (Loctite 574) sealant on the webs. I'm surprised that it would plug a squirter though because it shouldn't harden.
-Chris
Tom F2 11-11-2005 08:22 AM
I don't think it was 574. It was something dark brown and impossible to remove.
ChrisBennet 11-11-2005 08:34 AM
That's a good way to guarantee a warm afterlife. ;)
-Chris
cstreit 11-11-2005 09:15 AM
I've never used sealer on the bearing webs... However I've always used 574 which shouldn't necessarily harden in an area like that. One never knows though....
