Question assembly goo on exhaust studs??
Hi. Anybody know if I need to use any type of adhesive/goo on the exhaust studs? I took off the stock exhaust headers on my 993tt engine to get ceramic coated, and I decided to renew all 12 studs....so, when I install new studs, do I need to to any locktite or anything?? How about turbo's-to-exhaust studs...do I need anything here?
Jaime
Old 09-15-2005, 01:59 PM
syncroid's Avatar
Wurth makes a nice copper paste (like anti seize) that is perfect for this. I think it is CU-800. You don't want to locktight them. If they ever break off you want to make sure you can remove them again without a drill.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 09-15-2005, 06:55 PM
thanks for the tip...will try it!
Old 09-16-2005, 04:54 PM
I use Neverseez and it does a fine job. Haven't yet busted an automotive nut.
Ned
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 09-17-2005, 12:56 PM
Anti seize works great. If you have problems with header bolts coming loose go to a locking style header bolt. I just put a set on my cobra this weekend
Eric Hood
Old 09-19-2005, 06:47 PM
Unregistered
sammyg2's Avatar
If the fasteners used in a high temperature environment are steel, use anti-sieze. if they are stainless steel, paint them with milk of magnesia and you won't have any problem with galling or corrosion.
Old 09-21-2005, 11:16 AM
