-   -   engine stand (http://forums.pelicanparts.com/911-engine-rebuilding-forum/241917-engine-stand.html)
hillelson1 09-20-2005 05:55 AM
engine stand
does any one have or no where i can get a cheap engine stand for a porsche 911 engine
thanks
-larry
dweymer 09-20-2005 07:30 AM
it's the adapter(yoke) that's pricey; any regular stand will do. The porsche tool P201 engine yoke will allow you to split the case while on the stand without causing undue stress on the case.
JeremyD 09-20-2005 09:01 AM
I bought an engine stand from Sams - goodyear model... it was like $56.00 and folds which is nice. I also wanted one that had 4 wheels on the ground.
http://forums.pelicanparts.com/uploa...1127232052.jpg
Yoke from "mainlybydesign" Although I recommend this being spaced out another inch or so.
http://forums.pelicanparts.com/uploa...1127231899.jpg
dweymer 09-20-2005 09:42 AM
Jeremy, can you split the case with that one? I never found out and ended up buying the p-tool.
JeremyD 09-20-2005 09:48 AM
yep -
http://www.mainelycustombydesign.com/enginecomponents.htm#enginestand
Only thing I'd recommend is spacing it out a little further... I have about 4" spacers that came with the regular engine stand. I'd recommend at least 6" between the mounting surface and the surface of the engine stand (yellow part)
dweymer 09-20-2005 09:52 AM
d&mn, coulda saved a hunk o' money
