convertion turbo
is it possible to switch my turbo set up of my 3.3 to a 3.6 c2 motor? will the turbo stuff bolt up on the 3.6 long block and will the engine take it?
No, no and no.
3.6C2 motor is a very good candidate for turbocharging though. But non of 3.3 stuff is usable. You'll need new headers, lower C/R pistons, bigger injectors, different plenum, different ECU etc. etc. It's very rewarding conversion when done right, but if you believe that it's just a matter of unbolting few 3.3T grommets and installing them on 3.6 C2 engine, you are in for big surprise. |
| All times are GMT -8. The time now is 02:06 AM. |
