Dry Sump oil fitting source
I'm need of the scavenge oil fitting that attaches to the case in size AN12. What are good sources?
Thanks Eddie 914/6 2.7 |
Otto's.
Here's what we do. Cut the stock oil line and weld on a steel fitting. This terminates the oil line just under the starter for easy access. It also allows you to clear the exhaust and when the oil line is disconnected for engine removal, the oil will not run out all over the floor.
We generally stock this oil line. http://forums.pelicanparts.com/uploa...1127664065.jpg http://forums.pelicanparts.com/uploa...1127664091.jpg http://forums.pelicanparts.com/uploa...1127664102.jpg http://forums.pelicanparts.com/uploa...1127664118.jpg http://forums.pelicanparts.com/uploa...1127664127.jpg |
Henry,
Thanks I'll stop by the local fittings shop and pick up a steel AN12 male weld-on fitting and fire up the welder. Eddie |
| All times are GMT -8. The time now is 11:43 AM. |
