-   -   would it work? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/244588-would-work.html)
Porschekid962 10-05-2005 10:02 PM
would it work?
can i stuff a 66mm crank into a 78 3.0 sc case or is that reserved for the 930/52 case? i have a 78 sc 3.0 case to play with and would love to put that crank in it since i have FINALLY convinced dad to let me build him a motor along with getting a hybrid.
damn porsche, too many options
ryder
evil car nut, tyson im sorry i havent been out, the local law enforcement wasnt happy with my BAC so a couple more weeks of no driving, i got off on a deal. catch ya'll later.
p.s. if your in socal and love porsche hit up the peterson museum. friend of mine that has a bookstore in old town pasadena has a steve mcqueen exhibit going on. read, jerry seinfeld's #21 gulf porsche 917, motorcycles, gt40 chase car from le mans, ferrari's, jaguars, fords, all steve's fun stuff.
bust me a vine im out
Henry Schmidt 10-05-2005 10:08 PM
Re: would it work?
Originally posted by Porschekid962
can i stuff a 66mm crank into a 78 3.0 sc case or is that reserved for the 930/52 case? .......
Not in an 911SC case.
3.0 Carrera and the 3.0 Turbo not to mention the 2.8 and 3.0 RSR case are the only big alloy cases that you can put aproduction 66mm crank in.
Porschekid962 10-05-2005 10:33 PM
Thank you Henry for that very quick response, what is it about the cases that allows the shorter throw crank to fit? Just curious and I think I will be calling soon about a pump. I spoke with you long long ago about something like this for a 3.0
Ryder, big ideas, not enough cash
Wayne 962 10-06-2005 02:25 AM
The flywheel ends are bigger on the later cranks, so there's a bigger hole (and flywheel seal) in the end of the case. You need a Euro Carrera case, or use a 962 crank with the later cases (short stroke crank with big flywheel end).
-Wayne
Henry Schmidt 10-06-2005 08:43 AM
The difference is more than just the flywheel flange. The main bearings are also different. 60mm for the 9 bolt crank and 57 mm on the 6 bolt crank.
