-   -   Case sealant on one side, right? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/246890-case-sealant-one-side-right.html)
philippeF 10-22-2005 03:10 AM
this is a logical theory.... what about my picture, nobody ?
thanks
Philippe
code7rpd 12-20-2005 08:40 PM
Henry,
When you use the 3Bond 1104 do you just run a thin bead on one of the case halfs and seal the case or do you run a bead and spread it out prior to putting the case together? If you run a bead is it a thin bead?
