-   -   MSII v3 MSQ File (http://forums.pelicanparts.com/911-engine-rebuilding-forum/246984-msii-v3-msq-file.html)
JohnJL 10-20-2005 02:34 AM
MSII v3 MSQ File
I'm attempting to tune my Megasquirt II v3, would anyone be willing to e-mail me their msq file? Will make things much quicker than starting from the generic 6 cyl profile.
I have received a MS1 msq, but it was corrupt and the embedded code didn't 'like' it...
thanks
Dadofour 10-20-2005 07:45 PM
John,
How far along are you in the rebuild process?
Than
irnwill 10-20-2005 09:06 PM
Email sent
JohnJL 10-21-2005 04:33 AM
Hi Than,
Bottom end all sealed up, top end comes together this weekend.
MS2 v3 board all together, just troubleshooting some max RPM tuning issues on the software.
Found a 912 donor car in Qld, trying to get up there to look soon...and you?
Dadofour 10-21-2005 05:36 AM
Struggling with the seller of the engine from May of this year to get the remining parts. Expect the flywheel this week so I can start checking the rod clearances and begin assembling the bottom.
Otherwise great. Two more late season track events (Watkins Glen and VIR) and then I start the engine in earnest.
JohnJL 10-21-2005 02:33 PM
What a pain.
Did you bother with boatailing? I had everything all sterile and ready to go back together and decided to go ahead and boatail, so I had to clean everything twice, that alu dust gets everywhere even if you tape up the oil passages. It only took about 4 hours, 4 carbide burrs on a die-grinder and 10 yards (er...meters) of emery cloth but it came out really well. So what if it doesn't make a difference...I got to spend a few more hours working in the garage!
Dadofour 10-21-2005 05:01 PM
Do you have any pictures of the inside of the case before you sealed it back up?
JohnJL 10-21-2005 05:21 PM
Yes, will post...might have the opportunity to take some more, one of the piston wrist pin springs just "jumped" inside the #5 spigot and I can'tfind it....will post the pics...
Dadofour 10-21-2005 05:26 PM
I hope you find the spring
JohnJL 10-25-2005 03:29 AM
Will,
Thanks a lot. I re-burned a fresh s19 file, followed by loading your msq file. Works great now, my RPM fault is gone. I must have had a corrupt file. For future reference, I have a v3 board, seems to like it fine.
Are you running twin plug on your EDIS setup?
Than, files to come shortly....
John
JohnJL 10-25-2005 03:40 AM
Will, I'm going through your ignition settings now, I notice some unexpected things about your file:
1. I know you said you are running a WB controller, but the msq file was set to narrowband?
2. Under "Ignition Settings" on Megatune, the file was set with:
Trigger Offset = 0,
Ignition Input Capture to 'Falling Edge',
Cranking Trigger to 'Calculated',
Coil Charging Scheme to 'Standard Coil Charging',
Spark Output to 'Going Low (Normal)'
However, Megasquirt site calls for the following settings for EDIS:
Trigger offset = 10°
Cranking Trigger to 'Trigger Return',
Coil Charging Scheme to 'EDIS',
Spark Output to 'Going High (Inverted)'
Are you running EDIS with the former settings, or do I need to reset/send the correct settings to the ecu?
thanks again
JohnJL 10-25-2005 01:55 PM
Case Pics
Than,
Let me know if you want any specific close-ups, I've got lots...http://forums.pelicanparts.com/uploa...1130273668.jpg http://forums.pelicanparts.com/uploa...1130273734.jpg
