Oil pump intermediate shaft snap ring
I've up-graded to a later oil pump as part of my '75 911S 2.7 rebuild and since the pump came from one engine and my intermediate gear assembly came from another, I have a question about the way they are joined. I don't know if there is supposed to be a snap ring on both the pump end and intermediate gear end of the shaft that joins the two. The PET catalogue doesn't show one on the pump end but does on the intermediate gear end. Seems like there should be one in each end since both parts have grooves in the splines just in front of the where the shaft joins them. I currently only have a snap ring on the intermediate shaft end.
Jack
Old 10-21-2005, 01:30 PM
Try not, Do or Do not
Henry Schmidt's Avatar
There is a snap ring on both the pump and the intermediate shaft the locate the oil pump drive shaft.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-21-2005, 01:38 PM
Thanks for the really quick reply, Henry. Now I just need to find a snap ring.
Jack
Old 10-21-2005, 02:02 PM
Author of "101 Projects"
Wayne 962's Avatar
Jack
Punch the part number into the search engine above, and you can order it online.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 (October 2018)
Check out our new site: Dempsey Motorsports
Old 10-24-2005, 05:33 AM
Email your address and I'll send you one for free.
Henry Schmidt
Ph: 760-728-3062
Old 10-24-2005, 06:44 AM
Thanks Wayne and Henry. I found a local source of metric snap rings and actually got everything installed and the case closed up this weekend.
Jack
Old 10-24-2005, 08:48 AM
