Insane Dutchman
Will a 993 Crankshaft fit in an '84 case?
Hey guys, I am musing.
My Porsche parts guy says he has a 993 crankshaft available (apparently in pretty good shape) and was wondering if I wanted it.
For background, I have a new (as in brand new, never used) 1984 case that I am using as a basis for my engine build. General plan was to use the 74.4mm crank as used standard in the '84 case, 98mm Mahle P/C's and the heads from my 930/03 donor motor. From what I have read, this is a pretty good combo with TWM intakes, SSI's and something like a TEC 3 engine management system.
I must confess ignorance on the 993....but I am suspicious that it is different enough that it is not suitable....can anyone offer a definitive yes/no on whether it will work?
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 10-27-2005, 05:44 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
The flat answer is "yes," it'll work.
The general consensus is not to, from what I've heard and seen...
Scott Kinder
kindersport @ gmail.com
Old 10-27-2005, 07:14 PM
I am running a 964 crank in my 3.3. The 964 crank is the way to go if you are looking to stroke it in my opinion. Keep in mind the 993 crankshafts are not the correct journal size for a 964, 3.3 or 3.2 rods. If you go that route you need the matching rods and have to then figure out compression ratio with the pistons you choose
Eric Hood
Old 10-28-2005, 10:43 PM
Warren Hall Student
Bobboloo's Avatar
I would think you have to change rods regardless since your changing the stroke.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 10-29-2005, 08:46 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Originally posted by Wayne at Pelican Parts
In general, you have to keep the rods with the crank if the stroke is the same - it's an almost universal rule with all of the engines:
2.0/2.2
2.4/2.7
3.0
3.2
etc...
-Wayne
That's true as a general rule of thumb, but like you alluded to there are exceptions...
For example, increasing the displacement of a 3.2L to 3.6L uses Mahle 100mm pistons/cylinders (the same used in a 3.5L conversion) along with the 76.4mm 964 crank. This conversion retains the standard 3.2L rods. The 100mm pistons are specially machined to work. There are/were alot of these conversions running around (both normally aspirated and turbo) in the late '80's/early '90's before transplanting a 3.6L became both more cost effective and a better starting platform.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 10-30-2005, 07:05 AM
Warren Hall Student
Bobboloo's Avatar
Hmm, so the small end of the rod rides higher in the piston to compensate for the longer stroke. Just shows to go you, there's more than one way to skin a cat.
Bobby
Old 10-30-2005, 10:41 AM
Jeff Alton's Avatar
The 3.2 and the 3.6 964 rods are dimensionally identical....
Cheers
www.turn3autosport.com
Old 10-31-2005, 03:23 PM
