-   -   Valcew clearance check - assembl one side only? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/248560-valcew-clearance-check-assembl-one-side-only.html)
JohnJL 10-29-2005 08:52 PM
Valve clearance check - assemble one side only?
I'm performing the dry assembly of the head and checking valve clearance according to Wayne's book...seems logical to me I really only need to assemble one side for the check, right? all along the way so far all my left and right side measurements have been spot-on.
thanks
edited for spelling...
Wayne 962 10-29-2005 10:48 PM
Nope, both sides may be different, pariticularly if one head on one bank needed to be machined slightly more. It's wise to check both sides...
-Wayne
JohnJL 10-30-2005 01:31 AM
Thanks Wayne.
I guess I'm asking if my #1 and #4 cylinder deck heights match, they valves all match, thr cams are new regrinds from John, and the cam carriers are known good, is there a risk that valve clearances on one side would differ significantly from the other?
Eagledriver 10-30-2005 08:40 PM
You will very likely see differences side to side. It doesn't take much longer to do both sides. I had about .010 inches difference side to side.
-Andy
aigel 11-03-2005 11:00 PM
Measure twice, assemble once. Once you got all the sealer on there and then find out you have an interference, you'll be really bummed.
George
