-   -   Camshaft front-to-back play (http://forums.pelicanparts.com/911-engine-rebuilding-forum/248764-camshaft-front-back-play.html)
JohnJL 10-31-2005 12:38 AM
I'm checking my valve-piston clearance with a dry assembly and have the right side camshaft in, thrust washer, 3 washers (per previous build) and the woodruff key installed. When I have the sprocket flange installed flush with the camshaft, the camshaft still has 2.1MM front-and back play. Is this normal?
thanks
JohnJL 10-31-2005 02:11 AM
Well I found once the bolt (this is an DR 20 on an 83 cam) was tightened, the play is gone.
Another question now...I'll do some searching but is there a way around the cam bar tool (p237?) tool?
It seems a but much a tool I'll only use few times.
Great post the other day on making your own early cam holder from a socket with a dremel...
aigel 11-03-2005 10:58 PM
I have used this tool. I can't see an easy way to make it. Lots of torque on those pins. Borrow it for a sixpack seems most reasonable!
George
Wayne 962 11-04-2005 02:28 PM
Buy it, then sell it on Ebay...
-Wayne
JohnJL 11-04-2005 06:52 PM
Wayne,
I always did, but now being in Australia, by the time it gets here and through customs it costs 2X the list price.
I've always been happy with and advocate buying from Pelican. My 993 wires, tune up parts, caps, filters, gaskets, and all the rebuild kits for my 911 engine have been top quality and I've received excellent support.
John
