-   -   To MFI or not to MFI (http://forums.pelicanparts.com/911-engine-rebuilding-forum/249124-mfi-not-mfi.html)
matty74 11-01-2005 07:47 PM
I'm planning my rebuild of my 2.7 L CIS 74.
I'm not sure weather I should go for MFI or Webbers.
kenikh 11-01-2005 07:51 PM
Why not go TBitz EFI? The MFI retrofit will cost you A LOT more money than carbs or EFI and the EFI can be bolted onto your existing CIS for the same price as a used set of carbs. Do a search; there's a lot of info out there.
matty74 11-01-2005 07:55 PM
will this give me the performance of webers, i'm going s cams and JE pistons
kenikh 11-01-2005 08:16 PM
Frankly, it should be better, since it has a wideband O2 sensor which adjusts F/A ratio on the fly. Throttle response is supposely similar to MFI as well. I frankly dislike carbs, so take the biases for what they are. All of the cars I own with carbs are all in process of conversion to fuel injection.
Henry Schmidt 11-01-2005 08:22 PM
..........The MFI retrofit will cost you A LOT more money than carbs or EFI and the EFI can be bolted onto your existing CIS for the same price as a used set of carbs.............
Old 2.7 40mm Webers 200 hp? $1200 to $2000 old school
New PMO 200 hp? $2600 to $3000 new version old school
Rebuilt MFI 200 hp? $2500-$3000 tractor parts but so cool
EFI? 200hp? Most cost $3500 + modern just like a Toyota
How is an MFI more expensive? A'm I missing something?
matty74 11-01-2005 08:27 PM
Henry,
Do you do gearboxes and engines for Aussies?
I have a 915 4 speed I want to update to a 5 speed I just want to exchange for rebuilt one but no one here really does this.
Not to mention what I want to do with the motor, I want an RS spec 2.7
kenikh 11-01-2005 08:37 PM
Originally posted by Henry Schmidt
[B]..........
Tony's kit that is specifically for converting CIS cars to EFI is MegaSquirt based and costs $1700, soup to nuts. Motec EFI, etc. are another ball of wax and MFI is actually cheaper there.
Henry Schmidt 11-01-2005 08:40 PM
We send engines all around the world.
Early gear boxes are our specialty.
Instead of an RS spec engine I would recommend something with a little more pop. Perhaps a little more compression and a more modern cam from DR cams.
We do an intake port/manifold conversion that offers great flow and still delivers low end performance.
Email or call and I'll make something work for both of us.
obrut 11-01-2005 09:39 PM
Matt
I'm in Sydney and have a spare MFI setup I would consider selling if you decide to go with MFI.
I have a 2.7RS++ spec motor (MFI, 10.5:1 pistons, GE80 cams, twin plug etc) in my RS replica track/rally car and it is simply fantastic.
Also, performance 9 or perhaps one of the bigger porsche wreckers or parts places might do a gearbox exchange. However, i wouldn't expect much for your 4 speed.
matty74 11-01-2005 09:59 PM
Ryan,
I have spoken to Dave at P9, although they are great blokes I get my parts from them he can't help me with a rebuilt box.
who else is there?
BTW I'm interested in your MFI, what do you want for it?
obrut 11-01-2005 10:20 PM
Matt,
Re. MFI - I PM'd you a price.
Re. gearbox - maybe call exoticars at silverwater, swan in WA or aporschapart in VIC. there's also some guy in rural WA that advertises in unique cars who has engines and gearboxes.
Bobboloo 11-02-2005 12:23 AM
Shared plenum and agressive cams like S cams don't work well together. The CIS setup has a shared plenum and even with EFI it will be hard to get it to run smooth.
Cheapest bang for the buck is still a used set of carbs in this scenerio but if you can swing it money wise the MFI requires less maintenance and performs better once it's set up right.
I love the novelty of MFI and it's relationship to Porsche in it's heyday when 917s were trouncing the competition. Those were the days....
matty74 11-02-2005 03:15 AM
On a stock 2.7 If I put on MFI what type of cam shafts can I use to gain performance with out having to change pistons?
Henry Schmidt 11-02-2005 08:15 AM
Stock CIS pistons offer a number of challenges. Valve to piston clearance being the major on.
In the past we have placed valve pockets in CIS pistons and the results were acceptable. (be it lower compression and only done to accommodate a customers budget).
If your project is (as most projects are) governed by budget concerns, I would look to our host for some very reasonably priced JEs and build and engine that will run on CIS, MFI, carbs or EFI and add the new induction later.
What engine configuration will run with all these intakes?
I'm not sure, what is certain is that it will be a compromise, but what engine isn't?
The key will be the cams. I would ask our resident expert John Dougherty what he would use. http://forums.pelicanparts.com/drcamshafts.com
Perhaps a version of a S Cup cam?
jpnovak 11-02-2005 09:50 AM
By all means contact John. I wanted to install a different cam on my 3.0. I want to keep the stack pistons and run the webers and SSIs that are currently on the motor. He advised a special intake and exhaust grind with the correct lobe center to maximize my existing compression ratio and induction while maintaining clearance. He also helped it fit my budget by suggesting specs that could be reground, not welded. The cams are nearly ready to be sent off for grind work.
What great service! We are very fortunate to have these experts helping out us enthusiasts. Thanks John and Henry and everyone else that contributes.
matty74 11-02-2005 10:57 PM
I'll go with Henry's excellent advice and do the pistons first
bumble 11-03-2005 03:53 PM
Matt,
When do you plan on doing your conversion and what will you primarily use the car for?
Mark,
914/6 2.7
matty74 11-03-2005 04:02 PM
Early next year street use
bumble 11-03-2005 04:46 PM
Hmmm...
I run a set of JE 9.5:1 in my current engine. Finished in mid 2003, it's done four tarmac rallys and a couple of seasons of club sprints.
After Rally Tasmania in Feb I'll be building a new (smaller) engine and will probably sell most everything except the heads and ancilliarys of my current engine.
The timeframe may or may not suit. Just a thought.
Mark
matty74 11-03-2005 05:15 PM
I have sent you PM
