-   -   Leakdown tester (http://forums.pelicanparts.com/911-engine-rebuilding-forum/249401-leakdown-tester.html)
rlane 11-03-2005 11:01 AM
Leakdown tester
I am finally getting ready to drop my engine and replace head studs/top end job. I have not done a leakdown test on it and want to. Question is that the super nice Snap-on tester retails for $299. I see inexpensive testers on eBay for $75. Now I usually prefer really good tools but has anybody used these less expensive leakdown setups? In this case I and a buddy might use the tool twice a year, not several times a week like a real shop. Is there an issue with accuracy of the inexpensive testers ? Or of course any local Pelicanites that want to let me borrow one....
Jeff Alton 11-03-2005 11:20 AM
The accuracy is related to the quallity of the guages. The basic hardware should all be pretty similar. I have used a cheaper one for years with out any problems. .... You could always get a cheap one and replace the guages if you were really concerned about them.
Cheers
syncroid 11-03-2005 01:52 PM
I have been using one of the less expensive ones for years and it works fine. (till I dropped it the other day) :O
This is it, or was it.
http://forums.pelicanparts.com/uploa...1131054647.jpg
code7rpd 11-03-2005 07:43 PM
Tavia Performance makes a good one and it is not too expensive:
http://www.tavia.com/cat8.html
Henry Schmidt 11-03-2005 07:58 PM
The two gauge types show differential pressures and tend to be more accurate.
euro911sc 11-03-2005 09:19 PM
I bought a used 2 gage Longacre one off ebay for less than $40. Worked fine after I resealed all the joints. I might swap the gages out at some point if I have nothing else to do.
-Michael
rlane 11-04-2005 04:48 AM
Thanks guys, I scored one on eBay this AM for $50, time will tell!
RiskyBusiness 11-04-2005 06:04 AM
Leak down testers are not rocket science. I rolled my own using instructions found here. All the parts costs about $20. I got a regulator/gauge combo at Northern Tool
I upgraded it a bit by using an air hose with a swivel and a number of quick connects.
This is a motorcycle site but the same tool works for autos. I have created different ends for each motor I work on. I'm very pleased with it.
RiskyBusiness 11-04-2005 06:20 AM
