-   -   Engine Shroud (http://forums.pelicanparts.com/911-engine-rebuilding-forum/249688-engine-shroud.html)
EPorsche 11-05-2005 05:04 AM
Engine Shroud
How interchangeable are the engine shrouds from '74 to '87? What are the major differences?
Henry Schmidt 11-05-2005 06:57 AM
Generally speaking they are interchangeable.
Color and cut outs around the intake manifold are the basic differences.
I believe the 84 and later are made of plastic not fiberglass as found in earlier models.
EPorsche 11-05-2005 09:00 AM
Is the difference around the intake enough to worry about or can you mod it to make it fit easily?
