-   -   What's the typical efficiency factor of the 915 drive train? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/250839-whats-typical-efficiency-factor-915-drive-train.html)
Ho Hum 74 11-12-2005 06:42 AM
Just had my 2.7 MFI dyno'd and it came out at 195 hp at the wheels.
Any idea what the factor is? I'm told to divide by .85, but that would put my motor at 230 hp and I'm not really sure it has that much gas.
T
asphaltgambler 11-12-2005 07:49 AM
I understand that 15% is the standing number form the wheels to the flywheel
Eagledriver 11-12-2005 07:16 PM
My personal opinion is 10 percent. It's probably a bit more than that but I use this number to not fool myself into thinking my engine is more powerful than it is. That would put you around 215 which seems close to what I'd expect from a stock 2.7 MFI with "S" cams.
-Andy
Ho Hum 74 11-13-2005 07:26 AM
Andy,
My 2.7 has JE pistons of unknown compression and Elgin Mod-S cams. Should at least get another 10 hp.
T
Henry Schmidt 11-13-2005 07:53 AM
It is reasonable to conclude that if you increase the compression and improve cylinder filling with more lift and duration that the engine will make more horse power.
Is 20 horse power increase with in the realm of reasonable? sure
Ray 911s 11-13-2005 08:12 AM
T -
Where'd you get the dyno test performed?
I'm trying to decide how to build the "spare" 2.7, and it would help to have a leak-down and dyno run on the existing engine so I could calibrate the expense/benefit ratio on investment in the new engine.
Ho Hum 74 11-13-2005 08:13 AM
Porsche Exchange - Highland Park
