Wo ist die Rennstrecke?
DonE's Avatar
Oil Pressure Switch
What is the purpose of the oil pressure switch, located at the front of the engine, mounted to the top of the banjo bolt on a 79 930 engine? What does it switch?
The oil pressure sender and oil temp sender are located at the rear of the engine, next to the fan assembly, and I understand their functions.
Old 11-20-2005, 09:11 AM
JoeMag's Avatar
i thinnk it's for the low oil press light, only 70% sure though
Old 11-20-2005, 05:23 PM
DonE's Avatar
Yep, its the idiot light switch. Thanks
Old 11-21-2005, 06:37 AM
