chemicals to clean with?
I would like to clean the debri and carbon from the combustion side of the heads and the piston and cylinders walls.
Is it safe to use brake cleaner? How about something stronger like engine brite?
Old 11-13-2005, 03:58 PM
Super Moderator
cstreit's Avatar
Berrymans chemtool works well. SOak them in it for 24 hours then use a brass brush on the tops.... Or have the tops walnut shell blasted... TOPS ONLY!
Chris
2008 Yamaha R6
2001 GT3 Cup - "Pepin"
1999 Spec Miata
1996 993 RS Replica
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-13-2005, 04:46 PM
ChrisBennet's Avatar
I soak the pistons overnight in a little in water (upside down in a pan) or the parts washer. Then I dry them off, wrap some masking tape around the ring groove and then hit the tops with the wire wheel. I don't go nuts trying to get them super clean.
When I'm done with the wheel I take off the tape clean out the ring grooves with a piece of broken ring. When I'm done I wash them in dish soap and water, then rinse them in hot water and blow dry them a little with compressed air (all the little holes). I spray the now unprotect aluminum with some WD-40, measure them and set them aside until I'm ready to use them.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 11-13-2005, 08:21 PM
