-   -   What valve springs to use? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/251349-what-valve-springs-use.html)
hobieboy 11-15-2005 07:14 AM
Hi,
I'm rebuilding the engine and am debating on what valve springs to use.
My plan is to go with titanium retainers but am deciding on stock vs stiffer springs.
My understanding is that stiffer spring will both rob HP and put more load on the cam (hence wear).
So, does anyone know what safe RPM can the stock valve springs sustain?
The car is mainly used on track and I can see me revving regularly to 6700.
Thanks...
cstreit 11-15-2005 08:21 AM
I used the EBS VMAX valve springs in my last motor... Good for 7500 easy with a modified S cam. Used Ti retainers with it as well. 4 seasons and still good with no discrenable wear patterns on the cam (which incidentally is a hard-weld)
HawgRyder 11-15-2005 08:47 AM
Are the old Vasco-Jet springs still available?
We used to use them for the drag cars because they lasted so long.
The regular springs go "soft" in time but the V-J springs used to get "harder" after about 30% of their time.
They would be great for many more hours, then suddenly break after a long time.
We got used to that and changed them about once every 3 seasons.
Bob
Jeff Alton 11-15-2005 08:54 AM
Camgrinder who posts here often has two different sets available. Check out his website www.drcamshafts.com
Cheers
camgrinder 11-15-2005 09:23 AM
More information is needed. Things like cam selection, valve sizes, rpm range etc. If you miss shifts the performance springs are good insurance on a factory SC or 964 camshaft.
The racing springs are better for 7500+ rpm shift points.
cgarr 11-15-2005 09:26 AM
I am going to use the New Super Cup cams and performance springs from John when I rebuild this winter, which could be this weekend!! I think these springs are one step down from race springs? good to 7k without any problem
camgrinder 11-15-2005 09:30 AM
Craig,
yes they are good to 7k easily.
JoeMag 11-15-2005 09:36 AM
I have stock springs on my car. Red line at 6.800 rpm, and go there a lot. 3+ years no problem except a recent over rev way past 7k which broke an exh rocker. car has 964 cam, '82 930
camgrinder 11-15-2005 09:40 AM
Yep, the exact application for the performance springs. The SC and 964 cams are fine to 6800 with factory springs, but missed shifts cause problems like broken valve springs, broken rocker arms and dropped valves.
hobieboy 11-15-2005 10:43 AM
Hi John,
I have SC cam with a K27HF right now and am going EFI.
I am contemplating going with a 964 or your GT Evo cam with EFI, but as it stands, I feel that my torque is still flat enough all the way to 6500 rpm.
I haven't missed any shifts (so far) but go to & stay at the 6800 redline a lot - in fact, that's the reason why I'm rebuilding the entire engine. I had valve float right @ redline and seriously dropped & bent an intake valve.
I'm leaning on using Ti retainers with stock springs, and maybe shim it up a tiny bit? I thought this set up might cause less load on the cam/valve train but still give me some insurance?
Comments & suggestions?
thanks.
camgrinder 11-15-2005 11:16 AM
The Ti retainer with a new stock valve spring would work for the 964 profile. But your only adding a little insurance, not enough in my opinion. The GT2 cam wants more spring pressure for sure.
Shimming the stock spring for either cam will be tricky. Both cams have high valve lift. You will want to keep the valve spring about 1.5mm from coil bind.
hobieboy 11-15-2005 11:38 AM
umm... so should I go with your performance spring set up with Ti retainers? If I am not go to rev >7000, I dont think I'd need the racing springs?
How much more spring pressure is there between the performance & stock springs?
cgarr 11-15-2005 11:39 AM
Cant a high lift cam interfere with the valve guide seals too?
cstreit 11-15-2005 12:50 PM
OH YES. Particularly the teflon ones... BTDT
911pcars 11-15-2005 01:02 PM
For the record, anyone care to contribute some valve spring specs ?
Sherwood
KobaltBlau 11-15-2005 03:24 PM
Yes, a UK member recently had this problem with 993SS cams in his 3.2, if I remember correctly.
cgarr 11-15-2005 03:30 PM
I think I remember reading about that, I think you need to take off about 2mm on the guide for them to clear?
camgrinder 11-15-2005 04:09 PM
The factory spring typically installs at 60+/- lbs. The performance spring installs at 90 lbs and the racing spring at 110 lbs.
I do not make a Ti retainer for the performance springs. The factory retainer works fine.
The idea higher spring pressures cause premature wear or failures is valid. However at these spring pressures (110 lbs @ installed height) I am not concerned with these types of faulures.
cstreit 11-15-2005 05:45 PM
That sounds about right...
camgrinder 11-15-2005 11:12 PM
I wouldnt use 2mm as an absolute guidline. Every combination can be different. If you pulled out an SC cam with .450" valve lift and installed a Super Cup cam with .490" lift, the guide should only require 1mm removed. If you use aftermarket retainers, seals, or new valve guides you will have to measure the clearance.
911-32 11-16-2005 05:31 AM
Yes, my engine is the one referred to above (euro 3.2 with John's 993SS cam, race valve springs and Ti retainers among other things), the machine shop who did the work on my heads screwed up. The valve guides had to have 1.5mm taken off them after the initial rebuild as some of the seals were damaged. It was using a litre of oil every 200 miles more or less after a top-end rebuild plus new rings. Not happy at the time, but it all seems fine now and I got the engine pulled apart and checked after 1500 miles for free, so in the long run, not a bad result.
racing97 11-16-2005 07:49 AM
[QUOTE]Originally posted by 911pcars
[B]For the record, anyone care to contribute some valve spring specs
I have a little information from a project I did, what specs would you be looking for?
911pcars 11-16-2005 09:42 AM
Since I couldn't find them in the factory spec book:
Free length
Installed height (as I remember, the spec shows height including the retainer; would like w/o retainer as other manufacturers describe)
Coil diameter, OD
Wire diameter
Installed pressure (John helped with this one)
Thanks,
Sherwood
racing97 11-16-2005 01:53 PM
[B]
Free length
Coil diameter, OD
Wire diameter
Thanks,
Sherwood
Free Length on a stock 67-94 (years) spring is
1.625 on outer 1.5 on inner
installed height varies as to application 33.5 to 34mm (1.318 to 1.338 without retainers
spring seat thickness for outer spring is .194 and the inner .110 with the retainer offset .110 and the retainer is typically .070 to .080 thick if it is not Tiatainium so you would add .264 to the spring for the retainer and spring seat package.
wire dia. for outer is .150 and inner .120
Pressure or force valve closed is 32 for outer and 25 for inner combined for #57 lbs. @ 1.338 in.
Note the outer spring is pretty close to a progressive rate or non linear spring beacause of its windings and the inner is a typical constant rate.
sorry if this is fragmented
Best regards
911pcars 11-16-2005 04:21 PM
Thanks for digging up this info. Much appreciated.
Sherwood
racing97 11-16-2005 05:18 PM
My pleasure,
These are very interesting cars and information is hard to come by.
Best regards
