-   -   Marking Torqued Nuts (http://forums.pelicanparts.com/911-engine-rebuilding-forum/252392-marking-torqued-nuts.html)
euro911sc 11-21-2005 09:21 AM
I was thinking of using a perm metal marker to mark items I have torqued down. This is because I have kids and only get a few hours a week to work on putting the engine back together and am afraid I'll forget I torqued something or worse, think I did when I really didn't.
I am looking at the metal paint markers in the MSC catalog:
MSC Catalog Page: 2618
Should I be worried that this stuff will come off in the case and clog something vital?? Outside the case I'm not concerned.
-Michael
helidoc 11-22-2005 09:33 AM
You might check with the Aircraft Spruce catelog as in the aircraft industry they use a paint to mark the nuts and bolts that have been torqued. That way they also can inspect hardware and know if it has loosened during preflight and periodic inspections.
helidoc 11-22-2005 09:38 AM
Just checked out your link. I think I would go with the Industrial Markers if you are worried about stuff coming off and clogging an oil passage way. The paint tends to glob on.
euro911sc 11-22-2005 07:01 PM
Right, like a permenant marker. That way if it disolves then it wont clog anything. I bet a red sharpie would work just fine now that I think about it!
Thanks!
-michael
cstreit 11-22-2005 07:17 PM
I've used "anti-sabotage" stuff on external parts but I have no idea how it would react inside an engine... Permanent marker isn't on oily parts so that doesn't work (tried it). I use a yellow grease pencil. Temporary, harmless, does the job...
ChrisBennet 11-23-2005 04:02 PM
I just use a yellow crayon. It's probably not the best solution.
-Chris
cstreit 11-23-2005 04:22 PM
Chris that's totally simple and should work well at zero cost... Therefore we're all against that! :D
ChrisBennet 11-23-2005 04:29 PM
You know what a cheapass I am? A friend and I went in on a tire marking crayon and split it in half!
"Gee Mark, I'll never use a whole crayon. Go halfsies?"
-Chris
euro911sc 11-23-2005 06:00 PM
I know, first hand, how cheap Sir Bennet is! He cleans his parts with brake clean over a rose bush so he can fertilize the bush while he's at it... no joke!
did that thing blum again this year??
-Michael
remote messin' wit 911's member
