-   -   What tools do I need? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/252445-what-tools-do-i-need.html)
don hopkins 11-21-2005 01:46 PM
I am planning to try to fix an oil leak coming from the chain housing and the interface of the towers and the heads. What tools do I need? Should I do anything else while the engines out?
don
___________________________________________
1963 356B Super
1969 911S
1981 911 SC
Jim Sims 11-21-2005 07:06 PM
If I understand the leaks you propose to repair you will need quite a few tools. Dial guages and holders, straight edge and holder, cam nut wrenches, torque wrench and hex bits, etc. Do you have Wayne's engine rebuilding book?
don hopkins 11-21-2005 07:10 PM
Yes I do. But I thought I could skip some of the rec'd tools from the book.
safe 11-22-2005 01:11 PM
You can improvice the cam holder and cam nut wrench (if you have the early style cam nut 46mm), do a search.
don hopkins 11-22-2005 02:47 PM
Is there anyone out there who could lend the rebuilding tools?
