plymouthcolt's Avatar
JE Pistons and 3.2 swirled domes
In Waynes rebuild book (pg. 55) he says the JE pistons for CIS or 3.2 engines do not have the swirled piston domes that are distinctive to this model.
What are the consequences of using the JE pistons (part #212439) w/o the swirls? Will you lose horespower?
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 11-27-2005, 12:23 PM
Air Medal or two
afterburn 549's Avatar
probably a good thing...as they were esp for cis.......are you staying cis??
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 11-27-2005, 01:10 PM
PRO Motorsports
Tyson Schmidt's Avatar
The CIS pistons had domes that squished the combustion chamber over so that when the piston was at TDC, the effective combustion chamber had the spark plug near the center. This allows higher compression (due to shorter flame path) and leaner mixtures (without misfire) for lowest emissions and best efficiency.
It's not really a performance gain, as you can't run radical cams with these pistons, due to inadequate valve to piston clearance.
You won't lose horsepower. You will lose some efficiency though.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 11-28-2005, 01:03 PM
