aftermarket g-50 cross shaft
Received my new upgraded clutch fork and aftermarket non drill clutch cross shaft kits.
The new clutch fork came w/ nylon bushings installed, are these to be replaced with the brass/bronze ones in the cross shaft kit ??
KEITH EPPERLY
87 SLANT NOSE TURBO LOOK CARRERA CABRIOLET
Old 12-30-2006, 12:26 PM
yes. use a vise to squeeze them in. then you may have to do a little filing or sanding to get the shaft to fit without binding. doesn't take much.
206 637 4071
Old 12-30-2006, 08:15 PM
