diy83sc's Avatar
Intermediate Shaft Gear Pitting
This is my first rebuild and found some pitting on the gear. The second photo also shows a small crack. If it needs to be replaced, would it be wise to replace both the intermediate AND crank gears?
Thanks,
Tony
Pitting
Crack
Old 03-19-2005, 08:10 AM
i doubt that's a crack. the pitting is typical. it will eventually get worse and cause backlash (noise) between the two gears. you probably have some already. i know they're pricey, but if you're trying to do a quality rebuild, it should be replaced. the crank gear is usually fine, but at least check that it's still tight on the crank.
206 637 4071
Old 03-19-2005, 08:34 AM
diy83sc's Avatar
Yes, quality job is what I'm after. I did have some noise that I couln't identify with. Initial thoughts were chain tensioner issues, but when it came apart, all was well. Hmmm, maybe time for a WTB add.
Thanks John!
Old 03-19-2005, 08:49 AM
goldgunner's Avatar
Resurrection of an old thread...
I have about the same amount of pitting...
Problem is I have the # 1 size gear (930.105.136.01) which is NLA as 'gear only'~!!
The whole intermediate shaft assembly - # 1 size - is available, @ $ 601.75
So, with this level of pitting, for a 'quality rebuild', is the new shaft assembly appropriate? Unavoidable?
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 12-02-2005, 02:38 PM
Goldgunner,
I had this same dilema on my engine. I bought a 0 gear because I figured it would be better to have a new 0 gear than a worn out 1 gear. We'll it worked out perfectly. When I installed the new 0 gear there was virtually no backlash. If I'd have got a 1 gear I think it would have been binding. The 0 gears are available and not super expensive. I'd buy the new 0 gear and see how it fits. I think you'll find it to be a good solution.
-Andy
Old 12-02-2005, 04:31 PM
I can get ahold of 1 size gears. PM me if you like.
Old 12-02-2005, 05:15 PM
goldgunner's Avatar
Thanks guys~! Very much appreciate the advice and the offer.
A minor miracle: Troy at EBS came up with a new Size 1 Intermediate Gear.
Old 12-03-2005, 12:48 PM
