maad914's Avatar
930 oil inlet "thingy"
I'am going to use 930 oil filter/cooler block of plate in my 3.2.
Because that thing uses 3 of the 4 studs i'am wondering what kind of is the part which connects the oil line into engine case?
There is only one stud left for securing that thing.
Someone must have picture or even better, the part number.
Mika
porsche 914 3.2
Old 12-05-2005, 02:01 AM
Wo ist die Rennstrecke?
DonE's Avatar
Here is the part you are talking about. You can buy it at Smart Racing on line. Hope you are sitting down when you look at the price.
Most likely, you will have to replace the top two studs with slightly longer ones so you can properly seat the nuts.
You will notice I replaced the bottom two studs with hex head screws.
Good quality stuff from SRP.
Old 12-05-2005, 08:13 AM
maad914's Avatar
Yes, luckily i was sitting.
I will have that machined here, just need to draw it.
Mika
porsche 914 3.2
Old 12-05-2005, 10:17 AM
