Question Special nut in cam housing
When putting the case together on a 3.0 there is a special nut on the inside of one of the chain housings. Is there suppossed to be a washer there also?
Old 12-04-2005, 02:01 PM
Wo ist die Rennstrecke?
DonE's Avatar
If you are talking about the 17mm nut, it requires a steel washer.
Old 12-04-2005, 06:06 PM
That's the one. Thanks for the help.
Old 12-04-2005, 10:34 PM
ChrisBennet's Avatar
I think it takes a "wavey" lock washer doesn't it?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 12-05-2005, 03:39 PM
nut/washer
yes its a 10mm wavey and a plain nut,torque to 25 ft.#
Mike Bruns
Old 12-08-2005, 07:58 PM
Can the original washer be used or does it have to be replaced as a matter of course? I noticed that the nuts in the inside of the chain boxes are steel also (the ones that aren't nylocs). Do they need to be replaced or can they be reused?
Old 12-08-2005, 08:18 PM
washers
new ones are preffered but if they still have a good shape (not flat) they will work, a drop of blue loc-tite works well along with it.
Mike
Old 12-08-2005, 08:22 PM
Perfect - thanks!
Old 12-08-2005, 10:41 PM
