-   -   Let's play, "Predict the HP Game" (take 2) ---- this time with a 3.6L ;-) (http://forums.pelicanparts.com/911-engine-rebuilding-forum/254805-lets-play-predict-hp-game-take-2-time-3-6l.html)
TonyG 12-06-2005 06:15 PM
Where's camgrinder.....
I know you're watching. What's it gonna be?
TonyG
camgrinder 12-06-2005 09:45 PM
288.8 HP
TonyG 12-06-2005 10:17 PM
camgrinder
No hydraulic. Full mechanical.
I will run the dyno pulls 500 rpms past the peak HP readings. The top end is good (supposedly) for 8,000 rpms.
Gonna be interesting.......
TonyG
ChrisBennet 12-07-2005 06:55 AM
271.0hp at the rear wheels.
-Chris
afterburn 549 12-07-2005 12:14 PM
thats ez,, 3.5L bumped a lil =..... 341.5
crashmy911 12-07-2005 03:00 PM
my guess 300
911teo 12-07-2005 03:08 PM
At the wheels :confused:
That would be pretty amazing... 400hp from a 2 valves 3.6L aircooled N/A engine....
Not even the 3.8 RSR reached 111HP/liter ....
Dennis Kalma 12-07-2005 04:30 PM
262.7.....but hoping you have more!
afterburn 549 12-07-2005 05:11 PM
Lets see....1 L will put out a ez 60 hp times 3.5 some wheres around 210 plus additives (cam and ect good for some more.....dont know all you tricks).....but on the conservative you have to be 300 so all those guesses are taken and I needs a number here !!!....that's my formula and I am sticken to it.
TonyG 12-07-2005 05:37 PM
afterburn 549
You have two posts, both containing a "guess". Neither will count.
You have to only have 1 post that contains your guess.
Also, the power is SAE Corrected at the wheels (not engine HP).
TonyG
cgarr 12-07-2005 05:39 PM
302.66
Walko 12-07-2005 05:51 PM
If you allow that they get to 100Hp per litre then you get 360 at the flywheel allow for a %loss through the drive train and assuming the correct ramp rate is used then I would say
272.72 RWHP
Michael
afterburn 549 12-07-2005 06:08 PM
NoNoNO.....I was sort of explaining my too high of number..my 1 st one stands....thanks,,,,,,,OK??
TonyG 12-07-2005 06:42 PM
afterburn 549
No problem...
Just make sure you're clear on your posts.
Additionally, you can change your guess at any time before I "call" the end of the contest (see rules).
TonyG
dd74 12-07-2005 06:49 PM
TonyG
Oh, in that case, my guess is 268 hp.
ischmitz 12-07-2005 07:32 PM
267.567588549 :D
ZLP 12-07-2005 08:03 PM
277.96
YTNUKLR 12-08-2005 03:51 AM
278.3 @ the wheels
rdane 12-08-2005 10:28 AM
282.3
Bryan Beaumont 12-08-2005 10:34 PM
271.9
