3.0 Valve guides
I'd like to hear opinions on valve guides and seals for a normally aspirated 3.0 street motor. I've come across several alternatives.
Thanks, Randy |
alternatives to valve guides? do tell
OK, to be more precise...viton vs teflon seals...which bronze alloy guides? |
I am using the phos/bronze guides, seems like thats what everyone is using, the ones with the shoulder on them, makes the install too easy, the seals are what I get in the top end gasket kit which should be the black ones, not the white which I think are the teflon..
If they are like most you have to turn them dwn to size to fit the hole
| All times are GMT -8. The time now is 05:32 PM. |
