What are the differences between a 79 3.0 engine case and a 84 3.2L case?
I noticed the case numbers are the same but are these truly the same case? What are the differences and can a 3.0 case be used to rebuild a 3.2 Carrera engine without any more modifications? Are they both aluminum...I guess I'm just not sure, any help is greatly appreciated.
Best Regards, Alex |
no drain plate on 3.2. no place to mount the flywheel sensor bracket on the 79. painted dilivar studs on the 3.2. i built a carbed 3.2 engine using a SC case for my shop bus a while back. 92 turbo crank and rods, 3.2 P+Cs, 79 heads and SC cams.
Thanks John!
Any differences or advantages of 3.2L case from a structural standpoint? How did you ended up mounting the sensor bracket to the case? What I really need is a Carrera Standard case, I had mine repaired (heli-arc welded) but it slightly warped the case only on the intermediate shaft case corner. The repair itself was very well done but I should have pre-assembled the case first, instead I provided my welder the damaged half only. What to do? Best Regards, Alex |
i ran it with carbs, so didn't need the sensors. i can't think of any structural differences, but maybe someone else knows something.
| All times are GMT -8. The time now is 10:20 PM. |
