-   -   hp gain from bumping up to 3.2 s.s. and adding 1/2 pt compression? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/256943-hp-gain-bumping-up-3-2-s-s-adding-1-2-pt-compression.html)
jmz 12-19-2005 03:11 PM
question about hp gain from bumping up to 3.2 s.s. and adding 1/2 pt compression?
I have a nice running 3.0 with Mod S cams, 9.3:1 C.R., webers and some mild port work. It is pretty healthy.
I am thinking about putting some 98mm p/c and bumping the compression up to about 9.8:1 possibly going to 10.3:1. The heads are twin plugged already, I just need the ignition stuff.
How much H.P. and torque should I hope for by bumping up to a 3.2 S.S. and adding 1/2 or 1 whole point of compression.
T.I.A.
JayZ
