Eye of the Toiger
CIS cams Vs S Cams
I have a cis motor 2.7l I am rebuilding to RS spec.
JE pistons webers s cams what is the difference between the CIS cams and S cams? and will I get any better performance from DC40 cams over S Cams?
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
You will not be able to use either of those cams with the CIS. Too narrow a lobe center. Contact John, who makes the DC40 you are considering and give all the specs of the motor, and he will make a recommendation for you. The common plenum intakes CIS, 3.2 3.6 etc, don't get along to well with the more radical cams...
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Eye of the Toiger
Thanks, what about s Cams Vs DC40 the engine is for street use?
3 restos WIP = psycho
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Are you still using the CIS? If so, forget those cam choices. Will not work. If you are using ITB's, MFI, or carbs. then I would use the DC40 over the S cam.
Cheers
Eye of the Toiger
Yes Webers, (S Cams OR DC40), JE 9:1
The DC40 cams will have a wider powerband (3500 to 7500) than the S profile cams. They will also make more power and torque.
Set the compression ratio to 9-1 and go. The DC40's will be easier to drive around town. They will not work with CIS injection.
John Dougherty Dougherty Racing Cams |
Ok, sorry, was confused by the reference to a CIS motor in your original post!
![]() Cheers
E-cams are a great street and highway cam. It pulls better than a stock 3.2 according to every 3.2 guy that has rode in her.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
