-   -   Torque Specs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/257364-torque-specs.html)
code7rpd 12-21-2005 10:29 PM
Torque Specs
The Bentley manual reads the torque specs (page 130-4) for the oil line adaptor on the case as 89 ft lbs. and the oil pressure relief piston cap as 44 ft lbs. Does that sound correct?
ChrisBennet 12-22-2005 04:23 AM
I double checked using the Carrera Tech Spec book and that is right. (120Nm and 60Nm respectively.) Seems like a lot doesn't it?
-Chris
code7rpd 12-22-2005 08:06 AM
It does. I seem to remember someone on the board mentioning the oil adaptor fitting on a Carrera to be 24 ft lbs. but I guess not.
