-   -   What oiling modifications are required to 3.2 cam housing to match 935 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/257684-what-oiling-modifications-required-3-2-cam-housing-match-935-a.html)
BReyes 12-24-2005 07:45 AM
RE: use: with turbo twin plug crankfire efi track
BReyes 01-02-2006 10:16 AM
None of you have had this modification with large cams?
Porschekid962 01-04-2006 11:21 AM
Are you talking about center cam oiling? If I remember correctly someone else on the board building a hot rod motor had his cams machined through the center and outlet passages machined as well. Not sure whether he kept the spray bar or how the how assembly was connected. Are you sure you need to do this?
BReyes 01-14-2006 08:50 AM
I've been reading a little, on mods ( the early years before went to water cooled heads). There are mods that was made to 935.
Regards,
MBEngineering 01-16-2006 06:58 AM
HI i have the parts manual for the 1976 and 1977 935 cars, the cam box's 901 105 007 72 left, 901 105 008 72 right, if i remember are std' small 4 bearing housings, no mod's as such what are you building that you need to fit large bearing cam box's 3'2?????, the only mod's are to the heads and rocker covers on a 935.
regards mike
BReyes 01-22-2006 10:27 AM
Until I can find why not to use 3.2 housings/heads, I am reading on it. My understanding of it was more general and I am seeking specifics to coorborate.
