Engine 2.4 -73 cam help
Hi
I have a -73 engine that runs but no power. I have look at the camshaft and have following question. Crankshaft at Z1 (tdc). Left cam the dot(punch mark) pointing upward Right cam the dot pointing downward I this correct?? Differs the left and right cam from each other. Br Ake |
Both cams up, number 1 piston at TDC.
| All times are GMT -8. The time now is 10:27 PM. |
