-   -   Solder for deck height question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/258102-solder-deck-height-question.html)
code7rpd 12-28-2005 12:16 AM
In order to mesaure the deck height for a 3.2 SS with 964 cams what diameter of acid core solder do I need?
Thanks.
JohnJL 12-28-2005 02:57 AM
I believe you are aiming for a consistent deck height of .8 to 1.2 mm (meaning all cylinders at the same value, and that value is in that range) So you can pick a solder ~1.2 or marginally higher.
I used 1.2 standard solder w/o problems.
code7rpd 12-28-2005 08:46 AM
Great - thanks!
