Look at pics & tell me where oil is from
In the picks below my engine shows oil stains near where the cyclinder and case meet. Is this where the oil is from or is it from the breather cover?
Old 01-01-2006, 01:07 PM
Air Medal or two
afterburn 549's Avatar
more times then not is the oil P sender on top followed by breather/ "o" ring to thermostat/ followed by rocker shafts......BTDT everything else gets the blame but in the end it was so simple.........in my Case rocker shafts ( you could have never convinced ,proses of elimination did. university of hard knocks)
PS what with the belt thing??? and I am not seeing it (the oil leaks)
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 01-01-2006, 06:29 PM
Wer bremst verliert
JohnJL's Avatar
Another culprit could be the 'ole stretched/broken cylinder bolts. Any broken?
The definitive way to tell is to pour in some UV oil additive, drive it around, and get under there with a blacklight. You can usually find some from better auto stores (through they are getting fewer and fewer)
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 01-02-2006, 01:52 AM
safe's Avatar
Oil leak? where?
Thats not an oil leak
Magnus
Old 01-02-2006, 06:19 AM
Really! I thought it was. Thanks.
Old 01-02-2006, 07:35 AM
safe's Avatar
Hmm, there was small amount of irony in my reply.
It looks like a very minor (maybe you have cleaned it up in the picture) leak that is probably from the breather.
Change the gaskets in the breather cover, t-stat and preassure switch just to be sure.
Also change brather hose and clamp.
This is my breather leak:
Magnus
Old 01-02-2006, 08:04 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
The belt "thing" is for the MFI pump BTW.
And I agree...no leaks there that I can see.
Just years of dust and stuff going through the cooling fins.
Also...because of the rotation and air flow...if you did have a leak in the area of the breather or the oil send unit...the stain would go in the other direction (towards the oil cooler).
Bob
Bob Hutson
Old 01-02-2006, 09:41 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Oil leak - where.... See here for a real one that essentially killed the engine. The caked up oil prevented proper cooling of the heads/cylinders. Full rebuilt on my 3.6 - argh!!
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 01-02-2006, 09:49 AM
Thanks. But I have an oil from somewhere. When the engine was in the car oil would drip down on the right side onto the exhaust and smoke up alot. I have to figure out where it coming come. There is a leak somewhere. If I cannot find it have have to reroute the exhaust so the oil just drip onto the street. Very little oil has to be added to the engine but it still makes alot of smoke and the smoke is not coming from the exhaust itself.
don
Old 01-02-2006, 10:59 AM
ischmitz's Avatar
Rerouting the exhaust sounds like a pretty radical cure. If you can't pinpoint the source get a fluorescent stain additive. Do a search on the board. This will pin-point the source of the oil leak under fluorescent light. It gets mixed into the oil. Drive the car for a short while until the oil is warmed up and search for the traces with a black light source.
Cheers,
Ingo
Old 01-02-2006, 11:27 AM
BReyes's Avatar
Did you tighten all the oil lines?
Bernard
Old 01-02-2006, 12:00 PM
safe's Avatar
Don: If it leaks on to the HE I would look for leaks from valve covers, cam towers and maybe the oil cooler.
Magnus
Old 01-02-2006, 12:22 PM
I have already changed the valve covers, I forgot to mention this, and it didn't solve the problem. I will look again, but the oil cooler seems OK. So it might be the cam towers. What is the best sealant to use when I reassemble?
don
Old 01-02-2006, 01:04 PM
