Obligaotry CIS refresh parts
Since the engine is being rebuilt (78 Euro 3.0), I would like to freshen up the FI system. Which parts would fall into the "must" and "should" replace categories? It already has the pop-off modification. Thanks!
Brian |
Off the top of my head:
- Injector sleeves - Injector o-rings - Fuel filter - Fuel accumulator - Fuel pump check valve (I think you can order this separately) - All rubber fuel hose - Manifold rubber sleeves - CIS boot - Air filter All of these parts are in our CIS section: http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_FULcis_pg1.htm -Wayne |
Perfect. Thanks!
| All times are GMT -8. The time now is 01:00 PM. |
