-   -   Injector Testing (http://forums.pelicanparts.com/911-engine-rebuilding-forum/258969-injector-testing.html)
1972_911T 01-03-2006 05:57 AM
Injector Testing
Im wanting to test my fuel injectors to see if they need cleaning while there off for my eninge rebuild. Does anyone know how to trigger the injectors, I belive under normal operation its 12v pulsed dc voltage. What im wanting to know is can I trigger them to be constantly open by simply using 12v dc not pulsed?
Thanks Steve
ChrisBennet 01-03-2006 07:45 AM
I assume we aren't talking about a '72 motor here. ;)
You cannot use a non-pulsed source to hold them open - or least not if you don't want to burn them up.
Someone can correct me here, but I think in operation, the injector is opened initially by a greater current then what is used to keep it open. In other words, even using a pulsed 12v source might not be sufficiently safe.
-Chris
Zendalar 01-12-2006 05:44 AM
Depends if they are high or low impedance injectors.
If they are low impedance injectors they will burn up fast unless you drive them with pulsewidth modulated signal.
read more: www.msefi.com
