-   -   Engine Lubrication (http://forums.pelicanparts.com/911-engine-rebuilding-forum/259139-engine-lubrication.html)
CMW Motorsports 01-03-2006 07:42 PM
Engine Lubrication
Porsche Owners......If you want to protect your engine and add some horsepower you need to use Entech Engine Oil Additive. This special formulated oil additive will be available at the end of January.
Lubrication Information
http://www.pelicanparts.com/support/smileys/wat2.gif[/img]
You will notice in the near future that any lubricants that contain too much Moly or Teflon is not good. We have been fortunate to be with the best race teams solving there oil lubrication issues. The fact is that oil that contain to much moly shows NO Advantage for your engine.
Since we are in the business, there's a SAE Document stating that fact.
2006 you will see different manufactures getting away from any type of moly or teflon materials.
You will also see many of our automotive products in major manufactures including camshaft,connecting rods & valve train.
Our industrial products are already in major companies including trucking,BP West Coast Products-Vinvale Terminal / Motor-vehicles,city etc.
If we can be of any assistance or if you have a question concerning lubrication you reach us through this forum or you can email us @ info@cmwoil.com
got lube?
Scott Cousimano SmileWavy [img]
Jim Sims 01-03-2006 07:59 PM
You really should engage an editor or even a retired English teacher to check your "advertising copy." Not getting verb and noun agreement correct (among other things) casts doubt on the product you are peddling. :rolleyes:
Any test data (using controls) to back horsepower gain and wear reduction (engine protection) claims?
2.7RACER 01-03-2006 09:00 PM
Go get 'em, Jim.
Mike Juzenas 01-03-2006 09:32 PM
Sounds like snake oil.....
YTNUKLR 01-03-2006 11:49 PM
http://forums.pelicanparts.com/911-engine-rebuilding-forum/254962-what-ever-happened-cmw.html
CMW Motorsports 01-04-2006 08:24 AM
CMW Oil Company "Snake Oil"
1st of all I would like to thank everybody that replied to my post.
I guess we have the best snake oil.
Why do the top Busch & Cup teams use our Entech Lubrication?
Every Top Racing Team that uses Carrillo Connecting Rods uses our product.
Here's a short list of customers:
CHE Precision(Manufacturer) Testimonial on Web Site www.cmwoil.com
Carl Wagner Racing Engines (Busch Engine Builder)
Jack Sparks of Carrillo Industries completely supports our products.
I guess we have some good snake oil.
If you have a issue with lubrication we would be more than happy to help. We solve problems and give results.
All of our products are compatible with petroleum & synthetic oils.
To request data or further information you can contact us
@ 562-903-4571
Scott Cousimano
lvporschepilot 01-04-2006 08:58 AM
You can have all the endorsements in the world and I still would not buy it. Heck, even Carol Shelby endorsed Lubramax and that stuff has been proven to be awful. There is not one major auto manufacturer that endorses the use of any engine oil additives and, I am sure that is for good reason. snake oil.
CMW Motorsports 01-04-2006 11:44 AM
Most Snake Oil & Oil Additives are not good. They contain to much moly and or teflon materials.
You won't find "Snake Oils" in the Busch & Cup Series. But you will find CMW Oil Company Lubricants.
All motor oils have additives. Some additives are just to costly for them to put in for the general public.
We have an additive that is reasonably price that gives your engine that added protection and a few more horsepower.
Most consumers will pay for standard synthetic racing oil that cost around $10 per qt. Whereas a high budgeted team will spend 10 times per qt to have the edge over his competition.
Our entire Entech Product Line is available
sammyg2 01-04-2006 12:53 PM
I just left a phone message with the gentleman in charge of the rotating equipment department at the BP refinery in Long Beach.
I'm going to get it from the horse's mouth, plus I haven't played golf with him in years and IIRC it's his turn to buy ;)
Jim Sims 01-04-2006 03:54 PM
Hard to determine what's in this oil additive but from the description of how it works it appears to be a chlorinated additive which functions well for sliding ferrous surfaces under boundry lubrication conditions (oil squeezed out by the pressure). Chlorinated additives are sometimes found in machining lubricants where they work well in the single pass, short time contact service conditions. They were generally abandoned about 40 years ago by automotive lubricating oil blenders due to corrosion issues. Corrosion is not a problem in racing engines which typically don't live long lives plus have their oil changed very frequently. I would be hesitant to use a chlorinated oil additive in a "street" car or one being kept for many years. Scott, What's the chlorine assay of "Entech Engine Oil Additive?"
CMW Motorsports 01-04-2006 04:49 PM
We do not use any chlorinated materials.
Those materials are actually classified as hazardous, and don't work in the automotive industry. I believe they use it some industrial markets which they should not.
Our Entech Product Line does not use any materials associated with any chlorinated molecules:)
Boxer 6 01-04-2006 05:33 PM
Aren't you guys happy I asked "What ever happend to CMW"? I've got ESP.
Jim Sims 01-04-2006 05:56 PM
So the CWM oil product line (Entech Engine Oil Additive) has no association with Entech Corporation (Energy Release Products Corp.) of Nampa, Idaho?
TimT 01-04-2006 07:03 PM
Its always great to see the open minds on this board..
Bruce Anderson in his original 911 Performance Handbook mentions and touts CMW heads..
Improved port design etc..
A company that researches and develops 4.0 and 4.2L conversions then goes on to develope oils and assembly lubes in parallel may just be on to something..
then again they may not
I for one will give a benefit of the doubt...
TimT 01-05-2006 06:40 AM
Also Cosworth recently came out with its own line of motor oil
Liquid Cosworth will this be labeled as snake oil?
Mike Juzenas 01-05-2006 07:50 AM
Yes but will you put it in YOUR engine? I might try something like this on my old Chev V8 but certainly not on my 3.6 until I see a large body of evidence (read: other 911 owners) who use it in regular day-to-day driving and see a net benefit as well as a sampling of those owners who have torn down their engines and also seen benefits (or at least no downsides). These engines are just too expensive to be experimented on.
It would be fantastic if this product raises the baseline for motor oil performance but, being an engineer and conservative, I prefer to wait at the sidelines until the benefits are clear and repeatable.
Cheers,
Mike
lvporschepilot 01-05-2006 08:41 AM
I remember when prolong first came out. They made note of several race teams using their product. Where are they now? I would not even use the great and mighty FAA approved AVblend. That stuff is FAA approved which is no easy task. Are you FAA approved?
DonE 01-05-2006 09:35 AM
Ouch...
On the other hand, why be FAA approved for automotive use? Strange question...
And why so hard on this guy? If you don't like it, don't buy it. It's not like he is pushing it on any of us. Looks like he could have targetting his customers a little better (since the price per quart is north of $10) though. I will stick with Mobile 1 or Royal Purple but I woundn't think of flaming someone for a new idea.
I'm glad someone is thinking outside the box - how else can progress be made?
CMW Motorsports 01-05-2006 11:39 AM
We would like to thank everyone on there comments, both good and bad.
You will be seeing more of our company products with major manufactures in the coming months.
Our main line for automotive is for Fastener Lubes & Assembly Lubes of rotating parts.
I see I open a whole can of worms with our oil additive. Like the gentlemen said in the previous post, don't buy it. But the people who are interested in purchasing our additive, we will have it available for purchase the end of January.
CMW Motorsports News
•Because of the high demand of our billet heads we are trying to expedite orders. Delivery for heads are 3-4 weeks.
•For all you engine builders: You can order all of our heads bare. You can finish to your specs.
lvporschepilot 01-05-2006 01:59 PM
ok ok ok. You guys are correct. I am flaming this guy for thinking outside the box. I guess I am just severely burned/bitter due to the plethora of fake companies claiming the same wonderful properties and promises cmw is claiming. I will keep my eyes open for independant technical data on this additive should it come available. Til then, I guess it is like the boy who cried wolf. Know what I mean?
paslantnose 01-13-2006 05:38 PM
I talked my GF into providing me with some of her own, personal "snake oil".
Though not a true "petroleum" based lubricant, personal test results have repeatedly verified reduced friction levels at higher than normal operating temperatures !
We cannot label this lubricant a true synthetic due to it's natural formulation.
We can however verify that it does NOT contain any chlorides, sulfates, Teflon or moly.
Please note that your personal results may vary depending on your GF or wifes dietary intake AND what time of the month it is when you do your actual testing.
The only claim we can truly stand behind is that this product has been in use and proven since the dawn of mankind with no adverse side effects whatsoever !!!
afterburn 549 01-14-2006 09:38 AM
Just one thing here. On race cars you will find all kinds of labels on the doors from oil to condoms -just advertisement, someone paid big bucks to get their product out there, In no way dose it mean that the car or driver is using it.
kevin1618 10-20-2009 12:02 AM
Dear All friends,
I am so glad to meet you all!
I am a lubrication equipment manufacturer,such producing ,designing ,and selling the lubrication equipment,lubrication system,grease pump,oil pumps ,pneumatic grease pump,air operated grease pump and others lube equipment.For more information please contact me and visting our homepage http://www.crodis.com.
Regards,
Kevin wang
Crodis
Msn:kevin16188@hotmail.com
Skype:kevin16188
Email:marketing@crodis.com
Tel:86-755-33813800
Fax:86-755-33813896
MP:86-15820762527
One-more-time 10-30-2009 08:15 AM
I believe PASLANTNOSE is experiencing a FISH oil base lubricant.
