964 cam timing in my 930
does anyone have the cam timing specs for 964 cams in a 930? does it differ depending on your requirements from the engine and if so, how?
Hi Andy,
I was given 1.68mm for my 3 litre turbo, but I've seen specs between 1.50 mm & 1.70 mm Cheers |
1.26mm from Dougherty Racing Cams
cheers Paul. Don, thanks for the spec. i knew i'd seen it somewhere recently (DRCamshafts!)
| All times are GMT -8. The time now is 04:13 AM. |
