Boring from 98 mm to 100 mm
I'm curious (and I apologize in advance if this question is silly). How much can the existing 3.2 liter cylinders be bored out while maintaining a safe wall thickness? If the cylinders can be bored out to 100 mm's or 102 mm's, that would seem like a cost effective alternative to buying new P&C's. (I understand that new pistons would have to be purchased). Thanks in advance!
Mark
1987 Carrera
2018 GMC Sierra Denali 2500 Duramax
2012 Harley Davidson FLHX Street Glide
Old 01-27-2006, 08:14 AM
Jeff Alton's Avatar
98 seems to be the standard.......
Cheers
www.turn3autosport.com
Old 01-27-2006, 01:22 PM
I think 98mm is about the limit. At 100mm it would be extremely thin at the bottom. Check with Henry @ Supertec. He can probably get you new 100mm cylinders for about the same price as a set of 3.2 cylinders and the cost to bore and re-plate.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 01-27-2006, 02:24 PM
With the cylinders for the 930, you're limited to 98mm with a 103 case spigot register, approximately 4" 101.6 on the 105mm register, and 102mm on a 106.50 or 107mm register. There really isn't any more meat around the studs to do anything more- the cylinders end off sealing off against the case like a vw 94mm cylinder at the 107mm register (~.140" ledge).
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 01-27-2006, 04:00 PM
Jeff Alton's Avatar
Charles, how big can we go with a 3.2 based motor using your cylinders and pistons?
Cheers
Old 01-27-2006, 04:52 PM
Jeff, I've done 102s in the past, but I don't stock those- I make them as needed, since it's a specialty part.
Charles Navarro
Old 01-27-2006, 04:59 PM
Don't the spigots get really thin at that point (102 mm)?
Mark
1987 Carrera
Old 01-28-2006, 05:56 PM
You end up with not a whole lot of meat around the studs when you open the case spigots up to 106.5 or 107mm from the 103mm. But nothing any different than what we get away with on other applications without sacrificing reliability. It all depends on the combination.
Charles Navarro
Old 01-28-2006, 06:07 PM
