-   -   best way to remove exhaust studs? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/261001-best-way-remove-exhaust-studs.html)
Ken911 01-14-2006 06:02 PM
getting to the reassembly part of my 3.3 turbo motor . About half of the exhaust studs were broken off where the nuts are seated. They all are sticking out about an inch or so. I got new studs today and tried to remove a couple of them by cranking on them with a pair of vise grips. no luck one of them actually started to twist (not unscrew) so I stopped. they are soaking overnight with penetrating oil. any other suggestions from someone who has removed a lot of these?
JohnJL 01-14-2006 06:21 PM
Try heating up the heads around the studs with ace, hit the stud with freeze spray and crank them out with the vice grips or snap-on tool ideally.
89turbocabmike 01-14-2006 08:48 PM
Ken, these are tough to get out in one peice. I hope you luck out with penetrating oil. As John mentioned, an acetalyene torch is your best bet. I haven't tried the freeze thing, but use a snap-on stud remover and impact wrench. An impact wrench's action seems to work much better than a breaker bar in my experience. If it breaks you need one of these tools from fellow pelican "A Quiet Boom" see this thread for more info:
http://forums.pelicanparts.com/showthread.php?s=&threadid=192188&perpage=20&pagen umber=8
mikey911 01-15-2006 02:14 PM
Ken,
I just removed 6 broken head studs in similar condition on a 3.0 with the devilar studs. I used an acetyline torch to heat up and found a set of stud removers at sears that worked pretty well and was able to remove all 6 without much of a battle.
Mike
1974 911coupe
ChrisBennet 01-15-2006 03:04 PM
Originally posted by mikey911
Ken,
Mike
1974 911coupe
Removing head studs is a lot easier than removing exhaust studs.
The exhaust studs often need to be drilled out.
-Chris
Ken911 01-15-2006 04:47 PM
well made some progress about half of them have broken off flush and will have to be drilled out. one of the heads had time serts in it and those studs came out easily, so when i get all of them drilled out i'll install time serts so that in the future they will come out easily.
89turbocabmike 01-15-2006 07:04 PM
I'd also recommend the high-temp copper anti-seize and copper nuts as added safety nets:)
Ken911 01-16-2006 01:14 PM
no i have the silver anti sieze loctite N-5000 we use it where i work the copper stuff will stick so several years ago we switched to n-5000 or also n7000
john walker's workshop 01-16-2006 07:14 PM
http://forums.pelicanparts.com/showthread.php?s=&threadid=192188&highlight=exhaus t+stud+tool
kind of a long thread, but christian, aka "a quiet boom", makes the tool you need.
Ken911 01-17-2006 04:58 AM
I know, I e mailed him this weekend. been having some trouble finding the time serts though the ones every one sells in the kit are too short. They make the correct size but all the distributors sell the short ones not the longer ones that are the same depth as the threads in the head.
john walker's workshop 01-17-2006 07:05 AM
you usually don't need timeserts with this tool. google timeserts for a supplier. here, i did it for you. http://www.threadkits.com/timeserts/timeserts.html
safe 01-17-2006 07:16 AM
anti-seize?
If using anti-seize on aluminum parts, such as a head, an aluminum based anti-seize would be better right, or doesn't it matter?
john walker's workshop 01-17-2006 07:30 AM
why do they need to come out easily? i'd rather they stay in.
safe 01-17-2006 07:55 AM
True, chances are you will not have to remove the again anyway.
My question was more general. I have seen recommendations to use aluminum AS on lug nuts instead of copper if you have aluminum wheels. The reason to that should be that the copper would oxidize the aluminum faster.
Ken911 01-18-2006 03:54 AM
As far as getting them out easily I figure down the road when I put on headers, etc and break some of them off removing the heat exchangers I would like to be able to unscrew the studs and replace them instead of having to drill them out all over again
Ken911 01-18-2006 03:55 AM
Oh and John thanks for the link!!!
clarelaw 01-19-2006 07:04 AM
I had 9 broken on my 3.0 - I paid my machinist to pull them when he did the rest of my machine work.
peter915 01-22-2006 10:09 AM
I've just had my heads reconditioned and this included new brass inserts for the exhaust studs.
The studs where totally stuck, with the nuts siezed also. I blew the nuts off with Oxy and machine shop took the studs out & did the inserts. See http://www.cylinderheadshop.co.uk they did the work.
http://forums.pelicanparts.com/uploa...1137956907.jpg
Peter
davidppp 01-22-2006 12:33 PM
All this is costly stuff.
It is an everyday matter for a jobbing mechanic to get fasteners out with no fuss...or sub-let cost..
The answer is pateince and heat, in evry case.
If the nuts are solid to the stud, fine..decide if the stud needs to come out..if so, heat the std and the casting, and get lube into this join..Candle wax is bets of all..or use paraffin, or Plus gas etc..
But if the stud is Ok to reuse. just heat the nut..it will come off if treated gently and lubricated.
It should be very unusual to have to drill out etc..a sign of impatience..
Kind regards
porschezealot 01-26-2006 10:01 PM
did you ever resolve this? if not, try welding a more 'defined' piece of metal onto the stud, then try removing the piece of metal with vice grips.
john walker's workshop 01-27-2006 07:04 AM
you guys probably never had to deal with this from the sounds of it.
davidppp 01-27-2006 11:25 AM
Hello, John.
No, I've snapped plenty trust me!
However, as I get older I get more patient I guess..and with enough heat and stuff, I reckon most of them can be got out eventually..
Whether its quicker/chaeaper to just snap and drill out..not sure..can be bloody difficult from below, as you know much better than me!
What do you do now John?
Kind regards
john walker's workshop 01-27-2006 05:46 PM
heat helps sometimes, but rarely. the steel just gets a grip in the aluminum threads and rust and corrosion lock it in there. if it comes out, fine, if not cut them flush and drill 'em out, preferably with "a quiet boom's" special tool. if you drill off-center it will be hard to get the exchanger back on without elongating the hole in the flange. that would not be easy with the thick style flanges.
Jeff Jagusch 01-27-2006 06:11 PM
trick I learned years ago
A long time ago in my sports car club newsletter, someone submitted a "tech tip" for removing tough studs.
I've done it many times and it works!
Heat the head with a torch and then touch the stud with an ordinary CANDLE.
let is cool a bit and it should come out easily.
Might be worth a try?
Jeff
davidppp 01-28-2006 12:28 AM
Thanks John.
I guess you are right..it is a slow process freeing them up and very difficult in the car...I do not have the Quiet Boom jig..I'll get one..
Admission.have drilled off centre more than once..
It is a lot of work to drop the engine and strip the top end just to get at the studs with a proper bench drill..
Yes, I've used candle wax, as posted above..and it does work quite often...
It is a bit tricky to get the head boss hot enough , and quite easy to do damage with the acetylene flame of course..I've even wondered about getting some acid in there...
Kind regards
A Quiet Boom 01-28-2006 06:48 PM
John Walker keeps refering to "my tool" when in fact he had the original design. I happen to have a CNC mill and I'm making them for sale. Many of the folks who have used this tool have drilled so well that the studs threads come out like a spring. Using this fixture ensures a hole right down the center of the stud leaving only the threads behind, if the threads in the head are badly damaged at least you have a straight hole in the right location for a timecert. I've sold a bunch of these and gotten good feedback for the most part and since the original design I have modified the tool for better fin clearance as well as added a threaded hole to insert a long bolt for use as a handle in the even the tool is overly tight in the port. I'd be glad to post pics of the tool if you're interested.
Ken, thanks for the order BTW.
Ken911 01-29-2006 04:21 PM
no prob waiting for it to get here, I put int my 964 cams today only to find out the had sent the wrong set, so it will take a while to get that all sorted out i guess
